rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
No More Broken Head Studs!
I got my car back from Dan Jacobs today. Had to do a top end because of 7 broken head studs (posted during summer). Because of one of the broken studs, they had to split the case. Bearings were perfect. New seals, clutch, head studs, sound pad, rear shift bushings, tensioner oil lines, rings, rod bearings, chains and guides, breather, valve guides, exhaust valves, cam regrind, and oil return tubes.
While it was apart I had all the engine tin, fan, housing, strap, and valve covers powdercoated, and bought a new Rennline Stainless engine mount bar.
Before I took it in, I replaced the exhaust studs, added SSI and 2 in 1 out M+K, A/C and console delete, new heater boxes and cables, aluminum sump plate, heater hoses, backdated oil lines, O2 sensor, rear rotors, pads and calipers, tires, and tons more.
I can't believe how well it runs, drives, shifts, sounds now!
I didn't know the clutch could engage so easily, nor that the exhaust wasn't supposed to pop under deceleration. I forgot how smooth everything used to be.
I washed it, covered it, and parked it in the garage.
Thanks to Dan, Bela, and Robin at The Hairy Dog Garage, in Oxford CT and George at Proformance (powdercoating) in New Rochelle, NY.
Picture shows that I have plenty of engine detailing left, and I'm not gonna lie to ya— I think my new heater hoses clash with my fan housing. Can you say "heater backdate"? By the way, whats the best way to spruce up the intakes and other cast pieces while they are in the car?
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 02-02-2007, 11:56 AM
"O"man(are we in trouble)
widgeon13's Avatar
They do great work, Dan put a 3.0 in my 74 a long time ago and it was bulletproof. Too bad I sold it.
Old 02-02-2007, 12:51 PM
Somewhere in the Midwest
MotoSook's Avatar
Re: No More Broken Head Studs!
Nice looking engine. I'm curious as to why they had to splt the case for a broken head stud?
Old 02-02-2007, 12:56 PM
rs6er's Avatar
One of them broke off right at the deep end.
John
Old 02-02-2007, 02:18 PM
Congrats John. Glad it worked out well.
Sean
1982 SC D-Stock #372
NASA GTS2
1971T restoration in progress, read about it here:
http://911restorationmadness.blogspot.com/
Old 02-02-2007, 02:39 PM
great to hear you are back running again.. I should be this weekend again after a 4 month engine rebuild
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 02-02-2007, 02:58 PM
rs6er's Avatar
Thanks Ben & Sean. Ben- muffler sounds even better now.
John
Old 02-02-2007, 03:54 PM
19 years and 17k posts...
azasadny's Avatar
John,
Congrats! Enjoy the "new" car!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 02-02-2007, 06:48 PM
