-   -   RSR Conversion - Part 1 - The discovery (http://forums.pelicanparts.com/porsche-911-technical-forum/328824-rsr-conversion-part-1-discovery.html)
wachuko 02-09-2007 08:21 PM
Originally posted by Kaefer
Cool thread. I'm working on a '73 RSR project right now so some of this info is helpful.
Good luck with your project!
Now, now.... :) Share what you are doing as well. We all benefit. Got threads here going that we can see what you have done so far? SmileWavy
Edit: Found the roller you are selling: http://forums.pelicanparts.com/porsche-cars-sale/318109-backdated-81-sc-73-rsr-longhood-roller-8000-obo-va.html#post3041197
Do you have another project in the works?
wachuko 02-10-2007 06:05 AM
While I wait for my CDI box to return I started to take out stuff from the engine bay. Also bought a fan cover plate from here (Pelican) to cover the heater shroud I removed.
Before:
http://forums.pelicanparts.com/uploa...1171115798.jpg
After:
http://forums.pelicanparts.com/uploa...1171116131.jpg
Fan heater cover delete arrived. Here are a few photos of the install. The unit is made out of fiberglass and has no holes for the bolts. Easy to mark and drill.
http://forums.pelicanparts.com/uploa...1171116255.jpg
http://forums.pelicanparts.com/uploa...1171116294.jpg
http://forums.pelicanparts.com/uploa...1171116307.jpg
Now in place:
http://forums.pelicanparts.com/uploa...1171116335.jpg
http://forums.pelicanparts.com/uploa...1171116353.jpg
wachuko 02-13-2007 05:53 AM
No wonder people just cut the wires and are done with them... uff... I had to remove the pins from the plug to be able to pull the wires through the hole... Thanks to all of you that replied to my thread on this.
Anyway, I labeled the plug with number and wrote down where each one goes. Mirrors finally out.
http://forums.pelicanparts.com/uploa...1171336845.jpg
http://forums.pelicanparts.com/uploa...1171336883.jpg
SmileWavy
wachuko 02-13-2007 05:54 AM
I will finish removing the long A/C hoses and removing the rocker panels tonight.
randywebb 02-13-2007 11:54 AM
How much does that motorized mirror unit weigh?
wachuko 02-13-2007 11:59 AM
I will post the weight once I get home. Unless someone else can chime in. Post that I saw mentioned something like 10lbs for both... Will confirm tonight.
PcarPhil 02-13-2007 01:38 PM
Edit: Found the roller you are selling: http://forums.pelicanparts.com/showthread.php?s=&postid=3041197#post3041197
I was bent out of shape (still am) that this rust free roller needs to have the front pan replaced due to rust. I decided on holding off on starting the project till the first of the year and put it back on the market till then to see of someone wanted the project.
Well...I still have it...and I've started the project. I've gutted the car and am currently working on the sunroof delete. What a project.
This past weekend I stood back to look at my progress. I must admit - this is going to be a nice car!
wachuko 02-13-2007 01:45 PM
And... you know how it is...
http://forums.pelicanparts.com/uploa...1171403049.gif
:D Do you have a thread where you document the progress?? or a link to your website?
Best of luck! To me this is the best therapy in the world. SmileWavy
PcarPhil 02-13-2007 01:54 PM
No updated pics yet. I do plan to take some pics of the sunroof delete project and post 'em up here on Pelican.
wachuko 02-13-2007 07:38 PM
935 styled mirrors fitted... now I need to remove them and do the finishing touches before putting a coat of paint.
I did the bolt on the frame and will do the 3M special double face tape on the bottom.
On the passenger side I had to sand down and even out one of the sides to make the mirror align even to the frame.
http://forums.pelicanparts.com/uploa...1171424177.jpg
http://forums.pelicanparts.com/uploa...1171424223.jpg
If someone that has these mirrors can post a side shot of them I would appreciated... somehow the gap from the bottom of the mirror to the door does not seem correct... The double face tape will fill the gap but just want to compare to other folks with the same setup in their car. Also, if you can post the vendor/provider of your 935 styled mirrors it will help.
http://forums.pelicanparts.com/uploa...1171424255.jpg
http://forums.pelicanparts.com/uploa...1171424279.jpg
I have a black piece of vinyl that will cover the hole that can be seen from the inside. I will just glue that piece to the mirror. But here is a photo of what the mirror looks like from the inside of the car without the vinyl in place:
http://forums.pelicanparts.com/uploa...1171424313.jpg
That is all for now... did not get a chance to do much today...
SmileWavy
wachuko 02-15-2007 04:28 PM
Front arrived today from GT Racing via DHL:
http://forums.pelicanparts.com/uploa...1171585506.jpg
http://forums.pelicanparts.com/uploa...1171585524.jpg
http://forums.pelicanparts.com/uploa...1171585546.jpg
http://forums.pelicanparts.com/uploa...1171585570.jpg
http://forums.pelicanparts.com/uploa...1171585594.jpg
http://forums.pelicanparts.com/uploa...1171585619.jpg
http://forums.pelicanparts.com/uploa...1171585664.jpg
http://forums.pelicanparts.com/uploa...1171585684.jpg
http://forums.pelicanparts.com/uploa...1171585711.jpg
http://forums.pelicanparts.com/uploa...1171585732.jpg
wachuko 02-15-2007 04:33 PM
A few more...
http://forums.pelicanparts.com/uploa...1171585810.jpg
http://forums.pelicanparts.com/uploa...1171585825.jpg
http://forums.pelicanparts.com/uploa...1171585845.jpg
http://forums.pelicanparts.com/uploa...1171585880.jpg
http://forums.pelicanparts.com/uploa...1171585911.jpg
http://forums.pelicanparts.com/uploa...1171585932.jpg
Need to start fitting all this and getting rid of the old fenders and bumper if not I will run out of space in the garage in no time...
http://forums.pelicanparts.com/uploa...1171585953.jpg
Facey 02-15-2007 07:09 PM
i think that is already the definition of our of space.
lol
-just read your wheel thread- excellent choice of wheels 11/14x17 BBS's...very nice.
i think your going to make a very nice car, i hope to see it in person one day...
wachuko 02-17-2007 12:19 AM
Well... got the urge to do something to the car today... ended up working until 2:30am... and here I am posting photos of the progress...
Removed the sills. Pretty easy stuff... First remove the two end covers (held in place with a phillips screw), then remove the rubber strip to get access to the bolts. This one just slides off or you can gently pull it out. Loosen the bolts underneath (don't take them out completely... no need and those also hold the oil lines). Take out the bigger phillips screws on the side and done. Sills out.
http://forums.pelicanparts.com/uploa...1171699847.jpg
http://forums.pelicanparts.com/uploa...1171699866.jpg
The line you see hanging is the A/C hose... really tempted of just cutting it instead of trying to remove it in one piece.... :evilgrin:
Also finished installing the door panels... panels install easy... the part that took me a lot of time :banghead: was the power window switch... seems I forgot where the wires go in the passenger side and I can get that window to work from the passenger switch... it works from the driver's switch... after a few fuses blown I decided to leave it alone and search on the subject... can't figure out what the hell I did wrong...
http://forums.pelicanparts.com/uploa...1171699882.jpg
Then I started to take the front apart in preparation of fitting the new front...
http://forums.pelicanparts.com/uploa...1171699897.jpg
Fender removed
http://forums.pelicanparts.com/uploa...1171699918.jpg
http://forums.pelicanparts.com/uploa...1171699957.jpg
That thing is wide!! :eek:
http://forums.pelicanparts.com/uploa...1171699986.jpg
http://forums.pelicanparts.com/uploa...1171700003.jpg
http://forums.pelicanparts.com/uploa...1171700020.jpg
That is all for now... going to sleep... :bigbye:
Porsche 02-17-2007 01:33 AM
Mate, you have my utmost respect!!! :D That's a mammoth task, and you are making good progress really - the back flares are going to be the fun bit... ;)
wachuko 02-17-2007 05:58 AM
Thank you! The back flares... hummm... why do you think I am leaving those for last??... LOL I need to build up the courage to cut into the car... :eek: You could say that everything so far could be return back to normal... but once I cut into that sheet metal... there is no going back...
hawaiipcar 02-17-2007 10:01 AM
Great thread more power to ya for taking on this task keep us posted.
Johnny B 02-18-2007 05:40 AM
Heh congrats,
project looks great, best of luck.
Mine should be finished soon, will post more updates soon.
Johnny B
wachuko 02-18-2007 08:15 PM
Originally posted by Johnny B
Heh congrats,
Johnny B
Thanks. Always looking forward to your updates. Very nice car. If you read the first few posts on this thread you saw that your car was the one that got me to go wide. That and the photo of the car I posted in this thread. I will most likely copy your idea on the gas cap location and setup since .
Any chance you have photos of the inner fenders? Where the fender meets the firewall? On the inside? Looking for suggestions on how to attach mine. I thought about custom L brackets to attached to the original bolt clips...
SmileWavy
Edit:: I just read again your threads... your fenders where from a local source. Thanks anyway. Need to find someone that have used GT Racing fenders to help with the answer.
wachuko 02-18-2007 08:22 PM
Got some work done today...
Removed the driver's side fender, fitted the passenger side fender,
fixed the mess I made with the window switch wiring when I installed
the door panels :rolleyes: (no more blown fuses).
Here we go:
Passenger side fender fitted:
http://forums.pelicanparts.com/uploa...1171862175.jpg
http://forums.pelicanparts.com/uploa...1171862342.jpg
I reused the clips from the original fender. Fitment for the fender was very
good but there is some work needed toward the back of th fender (where it
meets the windshield. The material in that area is thin so while fitting it I put
some cracks on the gel coat. I will build it up from the inside to make it
stronger (too thin now). and to also fill the gap between the fender and the
door better. Too wide of a gap right now.
http://forums.pelicanparts.com/uploa...1171862232.jpg
http://forums.pelicanparts.com/uploa...1171862254.jpg
Here you can see the gap and the cracks in the gel coat:
http://forums.pelicanparts.com/uploa...1171862298.jpg
http://forums.pelicanparts.com/uploa...1171862314.jpg
On the inside, since there is no provision supplied to attached them to the stock
bolt holes, I plan on using some custom made "L" brackets to hold the side to
the stock bolts position and then buil up the area with some FG to make it look
nice and even (and to hide the L brackets added).
http://forums.pelicanparts.com/uploa...1171862277.jpg
I really think that the part that will give me the most amount of work to get it
right will be the bumper... it seems to stick out on the sides more than it
should. We will see once the driver's fender is fitted correctly.
Here is the driver side fender just resting on the car...
http://forums.pelicanparts.com/uploa...1171862202.jpg
Parts are starting to pile up... I will place a "For Sale" ad with all this (I need to
start the fund for rest of the body parts and the wheels & tires... 11x17 and
14x17, should be fun trying to find street tires for those wheels...):
http://forums.pelicanparts.com/uploa...1171862359.jpg
That is all for now !
