PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Originally posted by Kaefer
Cool thread. I'm working on a '73 RSR project right now so some of this info is helpful.
Good luck with your project!
Now, now.... Share what you are doing as well. We all benefit. Got threads here going that we can see what you have done so far?
Edit: Found the roller you are selling: http://forums.pelicanparts.com/porsche-cars-sale/318109-backdated-81-sc-73-rsr-longhood-roller-8000-obo-va.html#post3041197
Do you have another project in the works?
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 02-09-2007, 08:21 PM
wachuko's Avatar
While I wait for my CDI box to return I started to take out stuff from the engine bay. Also bought a fan cover plate from here (Pelican) to cover the heater shroud I removed.
Before:
After:
Fan heater cover delete arrived. Here are a few photos of the install. The unit is made out of fiberglass and has no holes for the bolts. Easy to mark and drill.
Now in place:
Drive safe!
1967 - Porsche 912
Old 02-10-2007, 06:05 AM
wachuko's Avatar
No wonder people just cut the wires and are done with them... uff... I had to remove the pins from the plug to be able to pull the wires through the hole... Thanks to all of you that replied to my thread on this.
Anyway, I labeled the plug with number and wrote down where each one goes. Mirrors finally out.
Drive safe!
1967 - Porsche 912
Old 02-13-2007, 05:53 AM
wachuko's Avatar
I will finish removing the long A/C hoses and removing the rocker panels tonight.
Drive safe!
1967 - Porsche 912
Old 02-13-2007, 05:54 AM
randywebb's Avatar
How much does that motorized mirror unit weigh?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 02-13-2007, 11:54 AM
wachuko's Avatar
I will post the weight once I get home. Unless someone else can chime in. Post that I saw mentioned something like 10lbs for both... Will confirm tonight.
Drive safe!
1967 - Porsche 912
Old 02-13-2007, 11:59 AM
Edit: Found the roller you are selling: http://forums.pelicanparts.com/showthread.php?s=&postid=3041197#post3041197
I was bent out of shape (still am) that this rust free roller needs to have the front pan replaced due to rust. I decided on holding off on starting the project till the first of the year and put it back on the market till then to see of someone wanted the project.
Well...I still have it...and I've started the project. I've gutted the car and am currently working on the sunroof delete. What a project.
This past weekend I stood back to look at my progress. I must admit - this is going to be a nice car!
Old 02-13-2007, 01:38 PM
wachuko's Avatar
And... you know how it is...
Do you have a thread where you document the progress?? or a link to your website?
Best of luck! To me this is the best therapy in the world.
Drive safe!
1967 - Porsche 912
Old 02-13-2007, 01:45 PM
No updated pics yet. I do plan to take some pics of the sunroof delete project and post 'em up here on Pelican.
Old 02-13-2007, 01:54 PM
wachuko's Avatar
935 styled mirrors fitted... now I need to remove them and do the finishing touches before putting a coat of paint.
I did the bolt on the frame and will do the 3M special double face tape on the bottom.
On the passenger side I had to sand down and even out one of the sides to make the mirror align even to the frame.
If someone that has these mirrors can post a side shot of them I would appreciated... somehow the gap from the bottom of the mirror to the door does not seem correct... The double face tape will fill the gap but just want to compare to other folks with the same setup in their car. Also, if you can post the vendor/provider of your 935 styled mirrors it will help.
I have a black piece of vinyl that will cover the hole that can be seen from the inside. I will just glue that piece to the mirror. But here is a photo of what the mirror looks like from the inside of the car without the vinyl in place:
That is all for now... did not get a chance to do much today...
Drive safe!
1967 - Porsche 912
Old 02-13-2007, 07:38 PM
wachuko's Avatar
Front arrived today from GT Racing via DHL:
Drive safe!
1967 - Porsche 912
Old 02-15-2007, 04:28 PM
wachuko's Avatar
A few more...
Need to start fitting all this and getting rid of the old fenders and bumper if not I will run out of space in the garage in no time...
Drive safe!
1967 - Porsche 912
Old 02-15-2007, 04:33 PM
user & abuser
i think that is already the definition of our of space.
lol
-just read your wheel thread- excellent choice of wheels 11/14x17 BBS's...very nice.
i think your going to make a very nice car, i hope to see it in person one day...
vini vidi vici
Old 02-15-2007, 07:09 PM
wachuko's Avatar
Well... got the urge to do something to the car today... ended up working until 2:30am... and here I am posting photos of the progress...
Removed the sills. Pretty easy stuff... First remove the two end covers (held in place with a phillips screw), then remove the rubber strip to get access to the bolts. This one just slides off or you can gently pull it out. Loosen the bolts underneath (don't take them out completely... no need and those also hold the oil lines). Take out the bigger phillips screws on the side and done. Sills out.
The line you see hanging is the A/C hose... really tempted of just cutting it instead of trying to remove it in one piece.... :evilgrin:
Also finished installing the door panels... panels install easy... the part that took me a lot of time :banghead: was the power window switch... seems I forgot where the wires go in the passenger side and I can get that window to work from the passenger switch... it works from the driver's switch... after a few fuses blown I decided to leave it alone and search on the subject... can't figure out what the hell I did wrong...
Then I started to take the front apart in preparation of fitting the new front...
Fender removed
That thing is wide!!
That is all for now... going to sleep... :bigbye:
Drive safe!
1967 - Porsche 912
Old 02-17-2007, 12:19 AM
Porsche's Avatar
Mate, you have my utmost respect!!! That's a mammoth task, and you are making good progress really - the back flares are going to be the fun bit...
Erwin
'97 Boxster (sold), '67 911S (sold), '77 911 (sold)
Definitive Australian/ New Zealand Porsche Resources
Old 02-17-2007, 01:33 AM
wachuko's Avatar
Thank you! The back flares... hummm... why do you think I am leaving those for last??... LOL I need to build up the courage to cut into the car... You could say that everything so far could be return back to normal... but once I cut into that sheet metal... there is no going back...
Drive safe!
1967 - Porsche 912
Old 02-17-2007, 05:58 AM
hawaiipcar's Avatar
Send a message via Yahoo to hawaiipcar
Great thread more power to ya for taking on this task keep us posted.
HAWAIIPCAR
75 911 S
Old 02-17-2007, 10:01 AM
Johnny B's Avatar
Heh congrats,
project looks great, best of luck.
Mine should be finished soon, will post more updates soon.
Johnny B
Challenge your limits, don't limit your challenges
911 RSR Jagermeister replica (Sold)
1987 944 Turbo cup (Sold)
Old 02-18-2007, 05:40 AM
wachuko's Avatar
Originally posted by Johnny B
Heh congrats,
Johnny B
Thanks. Always looking forward to your updates. Very nice car. If you read the first few posts on this thread you saw that your car was the one that got me to go wide. That and the photo of the car I posted in this thread. I will most likely copy your idea on the gas cap location and setup since .
Any chance you have photos of the inner fenders? Where the fender meets the firewall? On the inside? Looking for suggestions on how to attach mine. I thought about custom L brackets to attached to the original bolt clips...
Edit:: I just read again your threads... your fenders where from a local source. Thanks anyway. Need to find someone that have used GT Racing fenders to help with the answer.
Drive safe!
1967 - Porsche 912
Old 02-18-2007, 08:15 PM
wachuko's Avatar
Got some work done today...
Removed the driver's side fender, fitted the passenger side fender,
fixed the mess I made with the window switch wiring when I installed
the door panels (no more blown fuses).
Here we go:
Passenger side fender fitted:
I reused the clips from the original fender. Fitment for the fender was very
good but there is some work needed toward the back of th fender (where it
meets the windshield. The material in that area is thin so while fitting it I put
some cracks on the gel coat. I will build it up from the inside to make it
stronger (too thin now). and to also fill the gap between the fender and the
door better. Too wide of a gap right now.
Here you can see the gap and the cracks in the gel coat:
On the inside, since there is no provision supplied to attached them to the stock
bolt holes, I plan on using some custom made "L" brackets to hold the side to
the stock bolts position and then buil up the area with some FG to make it look
nice and even (and to hide the L brackets added).
I really think that the part that will give me the most amount of work to get it
right will be the bumper... it seems to stick out on the sides more than it
should. We will see once the driver's fender is fitted correctly.
Here is the driver side fender just resting on the car...
Parts are starting to pile up... I will place a "For Sale" ad with all this (I need to
start the fund for rest of the body parts and the wheels & tires... 11x17 and
14x17, should be fun trying to find street tires for those wheels...):
That is all for now !
Drive safe!
1967 - Porsche 912
Old 02-18-2007, 08:22 PM
