sugarwood's Avatar
In cold weather, over bumps, rear suspension makes "wet flip flop squeegee" sound....
You know that sound? Like chewing on rubber.
Or like a new pair of rubber soled shoes on tiled floor.
Or like wet rubber rain boots walking on dry floor.
Or like rubber rubbing on rubber.
I've noticed this mostly when it's cold out. What can this be from?
Hit a bump, and a rubbery sound when the rear suspension compresses.
Maybe the oil inside the shock is cold so there is more travel? Or less?
1986 Bosch Icon Wipers coupe.
Old 01-06-2016, 04:33 PM
My guess is that it is one of your rubber (or neopreme) bushings.
I recently replaced my trailing arm bushings and was shocked at how warn out the old ones were.
Old 01-06-2016, 04:42 PM
What he said^
Old 01-06-2016, 08:21 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+3.
I recently aligned the car but before that I swap the TB plates side to side and used some SylGlide. Worked for 3 days then squeek came back. Like you said only in the morning when cold. Once it warms up it goes away but initial drive is a bit embarrasing.
'85 Carrera Targa
PCA/POC
Old 01-07-2016, 12:29 AM
It usually comes from spring plate bushings that have been replaced with aftermarket rubber ones.
JR
Old 01-07-2016, 04:39 AM
Mine (81 SC) did this years ago. Local respected shop replaced the bushings.
Came back within a year. Only in cold weather, and with extension of the rear suspension (like over one of our antique, humped bridges.)
I try to ignore it.
1981 911 SC
2013 Mini Cooper JCW
2017 GMC K1500
Old 01-07-2016, 05:29 AM
