Brad w's Avatar
Rennshift question
Does the rennshift shifter center it's self between 3rd and 4th like the Wevo? I read where the Wevo does this but can't find anything on the Rennshift.
thanks
Just trying to clean up the SC, no race or track use now.
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 10-13-2009, 06:54 AM
Oh Haha's Avatar
Yes, it does.
Pacific Blue
Wayne
Old 10-13-2009, 07:40 AM
Brad w's Avatar
Good deal, Now which one is better for everyday use.
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 10-13-2009, 09:58 AM
tobluforu's Avatar
Do a search as I think there are few posts where users have had both. I have the rennshift, just installed it about 2 months ago and it's awesome! I have had the stock shifter, a welt ss and now this, and it made all the difference in the world. Very easy to install, but to get right it took me a few hours of driving/tweaking.
Old 10-13-2009, 11:38 AM
Senior Advisor
James Brown's Avatar
Just put a rennshifter in mine, great feel and it centers fine and the tension is adjustable along with the shift length and solid adjustable stops. see a theme here? it's fully adjustable! The stock unit is not. great feel from one shift to the next, almost jumps into the next gear! It does not, unfortunately, fix my old syncros ....
08 Cayenne Turbo
Old 10-13-2009, 05:12 PM
Almost Banned Once
sc_rufctr's Avatar
James
Time to rebuild? About time we had another 915 rebuild thread.
- Peter
Old 10-13-2009, 08:27 PM
Senior Advisor
I'm getting pretty good at shifting without the syncros, but yes sooooooooon
08 Cayenne Turbo
Old 10-13-2009, 09:07 PM
Make My Day
wowzer911's Avatar
If you're springing for the Rennshift or Wevo, you should definitely also get the PSJ shift coupling to go along with them.
74 911S Targa ROW
Building Designer/Business Owner
Old 10-14-2009, 04:47 AM
tobluforu's Avatar
So true, It changed shifting like I could not believe, but based on how old my trany is (org) sometime it feels like I'm trying to put a square peg through a round hole when putting ino first. No shifter will fix that.
Old 10-14-2009, 05:23 AM
Brad w's Avatar
Why? What are the benefits of switching?
Brad W 1980 911 SC
1982 928 Auto
2007 Hummer H3
Old 10-14-2009, 05:39 AM
Make My Day
wowzer911's Avatar
Coupler ends sloppy shifting caused by worn (and even new) factory couplers.
Why spend all that money on a precision shifter and not upgrade the coupler?
74 911S Targa ROW
Old 10-14-2009, 06:27 AM
X2.
There's also the Stomski coupler which accomplishes the same thing.
I purchased my Rennshift shifter (3) 911's ago and have moved it from car to car as I've moved on to different 911's. It's fantastic!
Old 10-14-2009, 11:34 AM
Senior Advisor
I put a wevo shift coupler in first a much better unit than stock, even the rebuilt or new stock unit has tons of slop. the wevo or rennshift or PSJ coupler helped out alot 0 play in these units. That and a good shifter is the only way to go.
08 Cayenne Turbo
Old 10-14-2009, 01:45 PM
Go Speedracer, go!
SpeedracerIndy's Avatar
Rennshift here, and only wish I had done it sooner. Plus, you can add a longer shift handle if you wish. A nice plus for even more adjustability.
Definitely go with a new aftermarket shift coupler as mentioned above. I got my Renshift working ok with the stock coupler, but when I switched to the aftermarket it was even better.
1981 SC ROW Coupe
Old 10-14-2009, 02:07 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
I have the Rennshifter and love it. I have the side spring tension set high with 2 washers each side which really centers things comming from 5th. I dont know if the wevo has tension adjustments or not in this area. Setup was a breeze, just put the car in 3rd gear, swap out the shifters and Viola!
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 10-14-2009, 02:08 PM
