haycait911's Avatar
what's the best dizzy for 2.7 w/webers???
I've searched but can't seem to find an exact answer. I'm currently running the original 2.4 dist. with the vacuum advance removed. timed to 4 degrees btdc @ idle (550rpm). I've tried the high speed timing but lose the timing mark entirely. what would be a good dizzy for my application? any thoughts? thanks! Don.
Old 02-06-2007, 09:35 PM
haycait911's Avatar
originally a 2.4 mfi engine/distributor, if it matters. Don.
Old 02-06-2007, 09:42 PM
frankc's Avatar
When I put Webers on my 2.7, I removed the vacuum advance and went with a custom curved mechanical advance. Stoddard did the re-curve for me. If you're interested, I can probably dig through my records and give you some data points for the RPM vs. Advance chart.
'73 911T RoW (Project)
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 02-06-2007, 09:44 PM
haycait911's Avatar
Frank, pm'd you, Don.
Old 02-06-2007, 09:52 PM
Early_S_Man's Avatar
Porsche Crest
Don,
There may be hope for your distributor, yet!
distributor lube...
Your idle should be 900 rpm +/- 50 rpm ...
Most recommend the RS 2.7 replacement distributor ... Bosch 0.231.184.004
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 02-06-2007, 10:08 PM
I use the RS 2.7
10deg initial & 35deg total works great for me. A new one comes w/cap and rotor. It should be around $300 if you call pelican as they didn't list it the last time i looked.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-07-2007, 06:16 AM
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 02-07-2007, 06:25 AM
frankc's Avatar
New vs. Old Distributor curve
Here are the data values and a plot of my old vs. new advance settings after Stoddard re-curved to match a 2.7 Carrera RS:
As you can see, the new curve is steeper, but falls off after 6K (which is plenty high for me).
Frank
'77 911S 2.7RS
'76 914 2.0
Early911SReg #2945
Old 02-08-2007, 09:05 PM
haycait911's Avatar
thanks a bunch, Frank!
Old 02-08-2007, 11:03 PM
