what's the best dizzy for 2.7 w/webers???
I've searched but can't seem to find an exact answer. I'm currently running the original 2.4 dist. with the vacuum advance removed. timed to 4 degrees btdc @ idle (550rpm). I've tried the high speed timing but lose the timing mark entirely. what would be a good dizzy for my application? any thoughts? thanks! Don.
originally a 2.4 mfi engine/distributor, if it matters. Don.
When I put Webers on my 2.7, I removed the vacuum advance and went with a custom curved mechanical advance. Stoddard did the re-curve for me. If you're interested, I can probably dig through my records and give you some data points for the RPM vs. Advance chart.
'73 911T RoW (Project) '77 911S 2.7RS '76 914 2.0 Early911SReg #2945 |
Frank, pm'd you, Don.
Don,
There may be hope for your distributor, yet! distributor lube... Your idle should be 900 rpm +/- 50 rpm ... Most recommend the RS 2.7 replacement distributor ... Bosch 0.231.184.004
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
I use the RS 2.7
10deg initial & 35deg total works great for me. A new one comes w/cap and rotor. It should be around $300 if you call pelican as they didn't list it the last time i looked.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
New vs. Old Distributor curve
Here are the data values and a plot of my old vs. new advance settings after Stoddard re-curved to match a 2.7 Carrera RS:
![]() As you can see, the new curve is steeper, but falls off after 6K (which is plenty high for me). Frank
thanks a bunch, Frank!
