ohecht
Guest
Posts: n/a
SC spark plug air seals - help
Does anyone know how to get new air seals over the plug wires? I've seen pictures of disassembled connectors, but my wires (which I assume are stock) do not look like they come apart at the connectors.
Thanks,
Olivier
82 SC
Old 12-02-2000, 10:21 AM
Early_S_Man
Guest
Posts: n/a
Olivier,
I have been told that the SC connectors unscrew from the wires as well. That would seem to be the 'logical' way to assemble them!
Warren Hall
1973 911S Targa
Old 12-02-2000, 12:39 PM
pbs911
Guest
Posts: n/a
I just got through doing my 78SC today, after reading all the threads on using non-braided wires on CIS, and Warren's suggestion of building your own from bulk wire, and from being tired of getting shocked every time I picked up a wire, and after discovering my grommets were gone. The air seal grommets were difficult to get on. I used ones from a local VW shop because they were 15 cents and porsche wanted $1.60 each. Ouch!! I had to pull then over the end that attaches to the plug. They fit, just takes a little finessing. The process will also provide the guys with a better visual understanding of the child birth process. It took about a minute or two, opf three per wire. But it worked.
And the best part - new plug wires for a total of about $18.00. (18 feet wire and 6 new grommets) Beats $250.00. I trusted you guys in the past threads on being able to use the non-braided. It runs great but I'll keep you posted if there are any adverse effects. And if there are I'll hunt each and every one of you down until I . . . . . (Oh did I say that out loud?)
Old 12-02-2000, 05:20 PM
howie944
Guest
Posts: n/a
A litle help on getting those air seals on. First remove the rubber seal on the bottom of the connector (the end that attaches to the plug). This may take a little bit of effort but they will come off. Once off the connector shaft is much narrower and you don't have to stretch the air seal as much. Also rub a little dish soap on both the connector and the hole in the air seal. they should slide right into place without a problem. The dish soap also makes getting the rubber seal back on a lot easier.
Howie
79SC
Old 12-02-2000, 10:12 PM
Superman
Guest
Posts: n/a
I had no trouble - they slid right on. It's what I like to call a 'honeymoon fit.' But the air seals are getting harder to find. the Porsche dealer here says P no longer sells them separately.
'83 SC
Old 12-02-2000, 10:27 PM
