THE IRONMAN
timing chain replacement
OK...!"/$%?&*...I am in the process to replace both timing chain on my 3.2...Left side is done...no problem there...On the right side, I linked the new chain to the old one and turned the crankshaft to feed it...No problems...I was almost at the end of the process...just to engage the master link...and the !"/$%?&* chain slipped off the intermediate shaft sprocket...I am probably not the first one to do that...so...How can I put back that chain at the right place on the intermediate shaft sprocket...??? Please...Help...!
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
What procedure were you using to replace the chains? Please explain in detail. It's important (IMHO) since you do not have the benefit of the strainer access.
Patton No Porsche at the moment but give me 6 months and then...... Last edited by Patton; 02-11-2007 at 02:05 PM.. |
Did that once,
The engine came out, Cam chain housing removed, Fished around with a coat hanger, wire, string, fed the chain around the sprocket and turned the engine by hand over. Pain in the butt!
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
THE IRONMAN
Read this:
http://www.pelicanparts.com/techarticles/911_carrera_chain_tensioners/911_chain_replacement.htm Notice where he made a flexible plastic tool. You might be able to use this tool to get the chain back on the intermediate sprocket. If not, you may be able to use the tool in reverse and pull the chain back, reset everything, and start over.
Patton No Porsche at the moment but give me 6 months and then...... Last edited by Patton; 02-12-2007 at 04:40 AM.. |
THE IRONMAN
Thanks Patton...I will work on that this week and will keep you informed with the winning method...
