930 transmission, no reverse
I have a '77 930 and can not engage reverse with the engine on or off, everything else works fine, what could be wrong and where should I start?.
Old 02-12-2007, 09:34 AM
Shift coupler adjustment or shift coupler bushings are bad. Look under cover plate on tunnel behind front seats.
Old 02-12-2007, 06:07 PM
i've repaired at least one reverse shift fork that was bent enough to keep reverse from engaging. under the trans end cover.
206 637 4071
Old 02-12-2007, 07:21 PM
