3.6 brains and wire harnesses
Let me see if I've got this right:
89-91 = aluminum intake w/ barn door afm 92-94 = plastic intake w/ barn door afm 95 = plastic intake w/ maf (obdI) 96-98 = varioram (us=obdII, row=obdI) What I'm trying to figure out is interchangeability of brains and wire harnesses - maybe with slight modifications. Thanks- Craig Backer |
Craig:
Pretty much all of the 964 ECU's will interchange: the .450 & .473 units. These are 55pin versions '95 993 ECU's (3 US versions) are unique to themselves even though they are 55pin units, too. '96-'98 ECU's are all 88pin units (3 US versions) and will interchange. The Immobilizer (drive-block) must be dealt with to start the car. (USA-only).
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Re: 3.6 brains and wire harnesses
My RoW '97 3.8RS vram is perfectly happy running in a '95. I was told that a chip would solve the immobilizer issue, but apparantly not so on to plan B for that.
Could you remove the varioram intake from a 97 us engine and install a 95 intake - using the 97's brain and harness? I was told you could. It just wouldn't run optimally under 5k rpm's. The reason I ask is because I have a 97 us engine that I need to run a 964 or non vram 993 intake on for class reasons (prc gt-l).
Bill-
I confused by your two posts. Are you saying you have a 95 block with 97 row vram intake, brain and harness in a 95 chassis? |
the '97 RoW 3.8 is in the '95 and the '95 US 3.6 is in the '76C3 w/ the RoW harness and DME
"I was told that a chip would solve the immobilizer issue"
That's absolutely correct for a '95 993!
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
Is the only difference between the 964 and 993 plastic intakes the use of a maf sensor compared to afm? That is, aside from the 1.5mm wider stacks and runners on the 993.
Thanks- Craig Backer Last edited by fastbacker; 02-21-2007 at 12:25 AM.. |
Paul S "Those who say it cannot be done should not interrupt the people doing it" |
Are you saying the 97 ROW dme with a new chip did not remove the drive block? |
In my case it is a US '95 DME and harness w/ a '97 RoW engine.
That's surprising. I was under the same assumption as lornfb. I thought it was just 96 and up that had the drive block.
This worries me seeing as that I'm close to buying a us 95 dme. |
I was told the same by several reliable sources, it may be true but so far hasn't worked out on mine. We will see as it is still a work in progress.
I guess I'll cross my fingers and hope the 95 dme I buy works with a chip.
My '95 DME had no driveblock. It also has a chip.
I recommend the Steve Wong massaged chip. He took dyno results and fine tuned the chip for my application. Doug
1971 RSR - interpretation |
