PeterCarrera84's Avatar
Send a message via Yahoo to PeterCarrera84
L f/r L side parking lights will not turn on, but...
Hello , I am a bit frustrated !!! My break light on the L side would not come on when brake was depressed. So I went and bought another #1157. well when I installed it it still would not come on until I put some pressure on with my fingers. I thought maybe it was the little contact that needed to be pulled forward to have a better connection,well I used a thin long screw driver, to pull the little tabs forward, well now neither front or rear light comes on, it does turn on only when the brake pedal is depressed !! other bulbs on the L side work fine , flashers, and turning signal
Why wont the brake light come on anymore ?? and the same with the front amber light on the L side..
Any one have an idea, where I screwed up ??%&*#% thats how I feel.,.
84 911 Carrera SOLD not forgotten
01 911 C4 factory Aerokit
76 914 rust bucket SOLD !!
03 Boxster S sold
98 944 S2 G Red,sold 04 FRC red Vette
Old 02-24-2007, 04:00 PM
check your fuses in the trunk. left and right sides are fused independantly, possibly brakes fused differently from parking lights. inside the fuse box cover is the legend for what fuse is for what function.
Tony G
2000 Boxster S
Old 02-24-2007, 04:45 PM
Thanks Tony G. I did that , I checked the fuses, they seem ok. also the side marker light Rear will not come on either, I traded bulb on the front r and l marker lights , both bulbs ok. I am running out of ideas.%#$&@ , better get some shut eye.
03 Boxster S sold
Old 02-24-2007, 07:12 PM
ground connections would be next on the list along with circuit continuity.
Tony G
2000 Boxster S
Old 02-25-2007, 05:07 AM
jpc1818's Avatar
Check your blinker switch and ground wires.
1989 C4 Coupe
1975 911 carrera 2.7rs Sold
1978 911sc Sold
2001 Boxster S
Old 02-25-2007, 05:46 AM
another day, good morning, blinkers work, flashers work, it all started to happen when i stuck a thin screw driver where the bulb for the brake light was, to bend it forward a bit. now all this side will not turn on the brake light and the side marker light and the front L amber lights. but when the break is depressed , or flashers on, or blinker on,, it works. If I shorted something, what would it be? There is power going to that side , but its selective. I will be home all day , checking , this forum, between my house chores. Carpet cleaning, attempting to organize the garage for the 10th time.//thanks for your imput guys !!! (:
03 Boxster S sold
Old 02-25-2007, 06:49 AM
Well, success, !!! fuse #4 how I missed that !!?? that blew of course when I stuck it with the screwdriver, and touched both tabs at once !!! what a dumb dumb !!! thanks , now to more interesting things, like replacing the damaged rocker panel R side, crunched when i changed a rear blow out some time ago// . I have the panel.
have a happy sunday !! here in Clearwater its going to a warm one.!!(:
03 Boxster S sold
Old 02-25-2007, 07:17 AM
