Somatic Negative Optimist
What is a PC 680? Is it the maintenance-free $60 wonder that can leak, eat the battery tray and release fumes into the trunk? ![]() Ah, I see; it's an Odyssey Dry-cell? So, how much would this PC 680 be in the Seattle area? And, does it have the "lips" to fit into a 911 tray?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Air Medal or two
Go tell your NAPA dealer to order you one / or our host may sell them. Unless you need a a 2 hour reserve with every thing on , it is the best way to go. IMO
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
Sounds good, afterburn:
Can you post a picture of the PC 680 installed in your 911, please?
does anyone have the correct part# for the optima red top battery that I would need for my 88 carrera. The more I read and search the more confused I get.
KC 88 Guards Red Targa (sadly sold )2005 Boxster S 1st Porsche 73 914 (long gone) |
KC:
The Optima Red weighs quite a bit, is not cheap and you have to make a holding-fixture (Adapter plate) for it. More search?
Air Medal or two
I am pic stupid still. I installed it in the most forward end of the car just off center (passenger side) Pc680 people makes a nice hold dwn bracket too.
Lots put them in the smuggler box, my theory is too much weight to the rear. Ran new BIG cables back to starter and one for ground. Will start, no problem even at freezing temps.
Make Bruins Great Again
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Kato,
The AGM battery in the Vector Jump-start pack is a typical motorcycle/lawn tractor battery with perforated posts ... i.e., not SAE battery terminals. Probably superior to SAE terminals in most respects, actually, if you are willing to alter the lugs on your battery cables! No, I haven't done this install ... just postulating on a source for a low-cost AGM sealed battery of 19 Ah capacity. My preference/suggestion would be a Miata battery for $92 ... the price has risen in the past couple of months!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Thanks much...................KC
Henri Owned for 21 years: '87 Carrera coupe Venetian blue |
Good choice, Henri.
Please, tell me the size and weight. Where did you buy it and how much? Many thanks, Gunter
Lordco; $197 check Optima power! for dimensions.
