Rennch on YouTube
Top Ten Projects for your 911?
As a "garage enthusiast", what do you suppose are on your top 10 projects you might need some direction on, maybe with pictures (or video) and some good tips?
I have a short list that I think would benefit a lot of people: * Brake bleeding/brake pad changes * Windshield installation * Flare (welding) install * Torsion bar indexing / Replacement * Front lowering * Alignment * CIS Tuning * Carb Tuning * Shifter Adjustment That's a quick, short list. Any others you can think of? I'm looking for things that 101 Projects maybe brushes on, but you might want more detail with. Thanks!
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
I'd add "valve adjust" in there somewhere for sure...
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Rennch on YouTube
good one.
Installation of Front Sway bar...
Include installation of bigger front sway bar (OEM). I find installing rear TB and indexing less strenous than installing a Carrera front sway bar.
TD |
Autobahn Garage
Door strap repair
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
-wheel bearing replacement
-fuel line replacement |
I am getting ready to try to identify my exhaust system. I have a '75 with the thermal reactor removed. I have new heat exchangers that I would like to install. I've heard bad stories on the headbolts and I'm not exactly sure what style exhaust system I have since it's had the smog stuff removed. What gaskets I need and so on. That would be a good topic.
Randy |
911 Turbo camshaft housing oil line restrictors takes care of oil foaming problems, also will increas oil pressure particularly at idle.
It's a quick, eazy and cheep mod. |
Rennch on YouTube
Thanks for the input everyone. Great ideas.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ Last edited by rennch; 10-23-2006 at 09:03 PM.. |
How about you buy Wayne's book? He has 101 projects for you.
81 SC, www.frankschroeter.com |
Rennch on YouTube
Go back and re-read my post, smarty pants.
I second the valve adjustment. What about lightening the car, stripping the carpet and prepping the interior for paint and installing a cage?
Rennch on YouTube
I like the idea of a valve adjustment, and stripping the undercoating.
durn for'ner
The valve adjust procedure is covered in 101 Projects. Or do you mean you would want it to be more elaborate ? Like including 2.7Racers method perhaps ?
Markus Resident Fluffer Carrera '85 |
THE IRONMAN
Fuel lines replacement.
Valves adjustment. Axle shafts/CV joints check. That's enough to keep you busy for a long period of time.
1984 911 CARRERA RUBY RED TARGA SW CHIPPED-BURSCH CATBYPASS MONTY FREE FLOW EXHAUST <IN GAS WE TRUST> |
Seems to me that the Pelican Search Function needs some exercising.
”101 MORE Projects for your Porsche 911...“ by Wayne Dempsey (9 pages). Of course there are top 10 lists for ’70 Irish green Sportomatic RHD. ![]() Best, Grady ![]() |
Rennch on YouTube
Grady....drop me a PM with you # if you would be so kind.
Bye, Bye.
Replace shocks.
Elvis has left the building. |
Rennch on YouTube
Good one Scott...thanks.
Autodidactic user
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions. ![]() 1973 911E Targa (MFI) |
