Early Speedometer rebuilt and working then stopped. Cable?
I just got my speedometer back from Speedometers.com and they did a great job. Well at least it was working for about 25 miles according to my newly working odometer and then stopped. Could it be the speedometer cable? Why would that go bad all of a sudden is what I am thinking. Any thoughts? This is on a 66.
Old 02-27-2007, 09:08 AM
So do cables just break? Fishy that it happened so close to when my new speedometer as installed. Any ideas? Any else have a cable go?
Old 02-28-2007, 11:03 AM
Speedocable?
Old 03-02-2007, 10:24 AM
<insert witty title here>
Christien's Avatar
Did the speedo just stop dead, as in no movement at all? If so, the speedo cable could have fallen off. Easy enough to check - I'm assuming you know how as you've already pulled the speedo out to send it in for repairs, right? Or it could've fallen off the transmission. See this thread on how to find that end:
Speedo cable tranny end???
If it's still attached at both ends, I'd be looking at the warranty on the work from the speedo repair. I guess the proof of mileage is pretty easy!
edit: I don't have a definitive answer as to whether or not speedo cables break, but I can't say I've ever heard of it. They're pretty rugged, and except for the transmission mount, the cable is all inside, so not exposed to road grime, water, etc.
Current: 1987 911 cabrio
Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster
Old 03-02-2007, 12:16 PM
I would rather be driving
jpnovak's Avatar
Pull the speedo, drive the car and look to see if the cable is turning. If not, you will need a new one. And yes... They do break. Replacement is a pain since you must fish it through the tunnel. Lots of stuff must come out for access.
Old 03-02-2007, 12:18 PM
