jryerson
Guest
Posts: n/a
Must change oil after using Techron?
I heard that Techron or other additives will stay in your oil and damage engine ,so you need to change your oil?
Jeff
78Sc
Old 12-20-2000, 07:37 AM
Drew_K
Guest
Posts: n/a
I don't use Techron, but I've read on this board that it should be added about 500 miles before your next oil change.
Old 12-20-2000, 09:41 AM
BRose
Guest
Posts: n/a
Their was a Porsche tech. bulletin that specified an oil change within 500 miles after adding Techron. This stuff I understand has been sanctioned by the PCA. I had been using Techron in my 944 since day one and I sold it with 335,000 miles without injector work, or engine rebuilding. That says something for this stuff!!!! For best results, it is recommended that you add a bottle of Techron when your tank level is very low. Fill up to 1/2 or less, drive until it gets down to 1/8 and add Techron again. You can smell it in your oil and it does thin out the oil as well since it does not combust and washes down through the cylinders. Just remember the oil change!! Good luck.
BR
'73T
Old 12-20-2000, 10:30 AM
Jdub
Guest
Posts: n/a
Porsche recommends that you put 20oz of Techron in the tank at fillup. Drive the car, HARD, and at 1/2 tank refill the tank.
I ran the Techron twice with fresh oil and replaced the oil following these two Techron runs, so the ratio for me is 2:1; immediate change of oil following depletion of second tankful.
jw
Old 12-20-2000, 10:44 AM
