Guest
Posts: n/a
What octane are you using??
I know octane ratings may be an issue for turbos, but what about the rest of us? I run normal, cheap 87 octane in my 3.2, and have for years. Never had any detonation. The dealer says that I HAVE to run at least 92 in my girlfriend's ML320. I've heard conflicting opinions over the years on this subject. I've always thought that if it didn't detonate, then it was OK.
------------------ -Richard '84 Carrera Cabriolet '74 911 Widebody 3.6 Project |
Guest
Posts: n/a
1973 Porsche 2.4l mfi 87 octane
1987 GMC Jimmy 5.7l 87 octane 2000 Chevy Z-28 5.7l 93 octane i just use octane level based on engine compression ratios. Craig |
Guest
Posts: n/a
103 HERE every time i can but at 5.50 U.S. a gallon not at often as i wish.
Regards Juan http://www.geocities.com/titos88911/MY911.html |
Guest
Posts: n/a
87 octane in my 78SC, but it has the lower 8.5 to 1 compresssion pistons.
P.S. Hows your turbo project v. 2 carat ring decision going? --------------------- Paul 78SC Targa |
Guest
Posts: n/a
I am running 92 octane in my '85 3.2 with chip. When I run 89 octane I get slight pinging under hard acceleration in 2nd gear.
IN my 73 blazer with a mildly built 350 (383) 9.2:1 Compression ration, I have to run 92 octane as well, or I get pinging. Nick |
Guest
Posts: n/a
I use 92 octane exclusively in my 3.2 with chip. I understand with a performance chip, you are required to use at least 92. Without, you can get away with 89 but if you truly loved your car, you would spend the extra 25¢ for Super.
![]() ------------------ Zach 77 911S 3.2 |
Guest
Posts: n/a
Ouch Zach!!!! I do truly love my car, and would be willing to spend the extra .25 per gallon, but need a good reason to!
Paul - I'm forging ahead with the project, without regard for the ring. I guess I'll try to swing both. I've hastily posted a few picks of my progress at: http://www.animotion.com/porsche_project/ ------------------ -Richard '84 Carrera Cabriolet '74 911 Widebody 3.6 Project |
Guest
Posts: n/a
1973 2.4 "T", always running on 93 Octane. Gas is cheap in Georgia ($1.40 avg for 93). Many mechanics insist on higher octane. If you consider the investment of your car why use anything else! BR |
Guest
Posts: n/a
I have an 84 911 and run premium .
I also Have a 2000 ML320 and run Mid-Grade fuel, and about every 3 or 4 fillups I use premium in the ML. Do not forget the ML is a Twin plug motor that is designed around being Emission friendly. In my 98 E320 I also ran nothing below Mid-Grade. Joe A |
Guest
Posts: n/a
92 oct here.
Matt 77 911S Targa |
Guest
Posts: n/a
93 Octane here. I have found that consistency is more of the key than anything. I always try to run gas from the same company and from the same station. Car seems to like it..if car is happy, I am happy.
Chris |
Guest
Posts: n/a
98 octane in my 10.3 compression euro 3.2.
It's what the manual recommends. |
Guest
Posts: n/a
Early MFI "t"s have the compression ratio of a lawn mower, so here in the N.E. I dont mind saving a buck or two. One day I'll have that new set of JE pistons...
Guest
Posts: n/a
Where in California is gas readily available with over an octane of 93?
Guest
Posts: n/a
Nowhere!! The best I could find when I lived in Vegas was 92.. Cali was the same... The only place I've found 93 is on the east coast..
Pete 77'Carrera3.0 ------------------ www.geocities.com/pcafaro2000/carrera30.html |
Guest
Posts: n/a
My 83 3.0 euro motor with 9.8:1 compression likes 87 octane...as long as it does not ping it is OK with me....
Guest
Posts: n/a
Used to always put in 92, but once prices hit $2.10/gallon I went down to 89. Not too much difference, as far as I can see.
------------------ Jeff 1976 911S |
Guest
Posts: n/a
87 octane works fine on my 86 Carrera. I have never had any problems with pinging even driving aggressively which is difficult to avoid.
I see no benefit in buring higher octane especially now that gas prices are so high. Joe Garcia |
Guest
Posts: n/a
only put 98 octane in 83 sc euro, not worth the risk of low octane fuel for a weekend car only
Bruce 83 sc |
Guest
Posts: n/a
89 Octane in the 911SC
47 Cetane in the Benz... ------------------ Hal '83 911SC |
