Would pulling on the speedometer cable tell me if its broken?
I unscrewed my speedometer cable and put a pair of pliers on it and I can pull on it and it has at most 1/2" of play but I cannot pull it out of the sheath. Would this indicate that it is not broken? When I drive, it does not spin as I put it in the cabin, I am stumped.
Old 03-09-2007, 02:02 PM
Early_S_Man's Avatar
Porsche Crest
Probably fuzzed-up on the broken end, and binding on the liner. Definitely needs to be replaced if not turning!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-09-2007, 03:23 PM
Zeke's Avatar
Did you pull on both ends? Did you check the drive gear with the car in the air and the trans turning?
Old 03-09-2007, 04:02 PM
Milt, no I pulled the speedometer and put the cable through the hole. While driving it does not turn. However I cannot pull it through the cable housing. I am confused as to what the problem could be?
Old 03-09-2007, 06:05 PM
Richard Burns's Avatar
Try removing it from the transmission end.
I am guessing that it has broken and split apart inside the cable housing causing it to catch as you try to pull it out.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 03-09-2007, 09:17 PM
To replace it do I use the old housing to pull through the new one? Which side of the transmission am I looking at to to remove this cable?
Old 03-11-2007, 07:18 AM
