joetiii's Avatar
Fog light switch question
So I'm hooking up my foglights and I'm wondering I can use my rear defrost switch for on/off. Now that the switch is useless since wiring did not go back in during restoration, I wonder if this pull knob can be used? Hmmmm
joe
'69 911 E Targa - aka "RoxiE"
Old 03-10-2007, 02:19 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Yes it can Joe. It's essentially the same switch as the fog light switch.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 03-10-2007, 05:16 PM
Sports Purpose 911 Driver
mjshira's Avatar
just don't use it to switch two things or you'll over load it. I would also suggest that you add a fuse to that power circuit so that you have added insurance.
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 03-10-2007, 05:53 PM
Suggest using the switch to energize a relay that actually provides source voltage to the fog lights. The relays result in less voltage drop (brighter lights) and saves wear and tear on the switch (just like the add-on relays for the headlight circuit).
Sherwood
Old 03-10-2007, 09:30 PM
joetiii's Avatar
Sherwood
I am definitely using a relay for this as the bulbs themselves are 100 watt and I'm sure they would toast the old wiring and switch. I imagine std 18 guage new wire to be acceptable.
joe
Old 03-11-2007, 05:56 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
100W fogs? Dang! I'm running H1 fogs at 55W.
16 AWG minimum! on the lines to the relay. Bump up the grounds too. The original Porsche under bumper fog wiring to the relay panels only saw a maximum of 35W H3s. The thru the grill wiring saw as much as the Italian H1s 55W driving lights.
Old 03-11-2007, 09:02 AM
joetiii's Avatar
My mistake... they're not fogs but rather thru grill driving lights and they're 1000 watts per light.
joe
Old 03-11-2007, 09:33 AM
"My mistake... they're not fogs but rather thru grill driving lights and they're 1000 watts per light."
Errr, or was that 100 watts/light?
At 1000 watts, you'd need at least no. 4 cable (almost a battery cable), but I think you meant 100 watts.
In that case, the charts recommend 12 gauge wire for the power side (from source voltage to lights). But that's per light. The control side (source-to-relay-to-switch) is okay using 18 gauge wire. If you use one relay, make sure it has the current capacity for two-100 watt lamps (25A-rated relay will do). You can also build a circuit with one relay per lamp in case one relay or fuse fails. It depends on how dark it is, how fast you're traveling and thus how much light will suffice.
Sherwood
Old 03-11-2007, 02:05 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
Sherwood
Yep, Sherwood is right. My mistake. Note to myself: Michael, repeat after me...When working on my car Think Low voltage circuit, THink Low voltage circuit..
Much more critical in the 12V circuit. It's not really a matter of the amperage here and what the wire can handle. It's the % voltage drop in the wire really and what that does to the overall light output by the time you reach the bulbs. Even though we're talking about what? Say less than 10 ft to the far foglight? Wait, that's on my 70. Your 69 will have the relays further up near the cowl?
Old 03-11-2007, 08:39 PM
joetiii's Avatar
I have relays up inside the cowl but have replaced them with new ones when I installed the H4s. I have a new relay and fuse for the driving lights that will be going in.
Not sure how noticeable a drop in power will be on 10000 watt bulbs.
joe
Old 03-12-2007, 07:41 AM
