msd 6 installation
another question regarding msd 6 installations!
I have a 79 911SC Euro and have a question on hooking up the wiring to these units. Does the purple and green wiring harness need to be attached to the MSD unit or do I use the white wire? I tried hooking up the white wire to the green wire in the connector via a spade clip and got nothing to fire. Do I need to hook up the green and purple wires? if so, what wires in the connector do they attach to? There is a green wire and a black wire going to the distributor but not sure which is which.
Also, does a spark plug gap of .055" sound about right? I have pistons with a CR of 9.3 and cams from a C2/C4. After my rebuild, I did not even get an inkling of combustion.....no start and flooded the bejesus out of it.
Thanx
Erk
PCA Member
restored 79 911SC Euro
green, mean and ready to rock
Old 03-11-2007, 06:31 PM
Yes the purple and green wires hook up to the green wire and the shielding around the green wire. The black wire you speak of may be the sheilding around the green wire, I'm not sure.
I don't know which way the wires go (purple to green or purple to black) but you can hook it up either way and see what you get. See my answer on the previous post about reversing these connections. If you end up with it wrong you just reverse them.
I use .040 on my spark plug gap. .055 seems excessive
-Andy
Old 03-11-2007, 09:36 PM
one of the local popes says .040 w/MSD.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-11-2007, 09:47 PM
Wer bremst verliert
JohnJL's Avatar
You may need a tach adapter too but try it first as andy says. Yes, .040 is right.
The MSD manuals showed just about every installation permutation and they've worked for me so check them.
I checked my MSD with an oscilliscope, it was cool to see the multiple spikes...and sure enough it goes to 1 spark over around 4k..
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-12-2007, 01:23 AM
fred cook's Avatar
If you will send me your email address, I can send a wiring diagram for installing an MSD-6 into your SC. I put one in my SC about 18 months ago and it has worked perfectly. Send your email to fred.cook@windstream.com
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 03-12-2007, 05:17 AM
