Irrationally exuberant
ChrisBennet's Avatar
MSD green wire with swapped wires
I could swear someone (recently) posted something about switching the wires (reversing the polarity) from the distributor to the MSD box (aka "green wire") and that results in a 15 degree retardation. Loren even posted something in the post. For the life of me I can't find it now.
I thought it was in the "Green Wire" thread but I couldn't find it.
Did I dream it? If I didn't, got a link?
thanks,
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 03-11-2007, 06:32 PM
randywebb's Avatar
current on Rennlist
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-11-2007, 08:14 PM
DP935 member
kycarguy 935's Avatar
Is this the one?
The Green wire...
Porsche Slantnose M505 M506 group on Facebook.
https://www.facebook.com/groups/719995181372494/
Old 03-11-2007, 08:38 PM
DP935 member
Or this one?
Green wire female connector
Old 03-11-2007, 08:39 PM
Originally posted by randywebb
current on Rennlist
Thanks!
Old 03-11-2007, 08:51 PM
Could someone please explain what will be gained from this? I have an SC with an MSD.
Thanks.
Old 03-11-2007, 09:11 PM
The engine will run with the wires hooked up either way. The correct way will give the proper timing and the wrong way will advace the timing by alot (20 degrees or so on my engine).
You can tell if you have it the "right" way by checking the static timing (looking at the magnetic wheel in the dizzy) and then running the engine to see the timing about TDC. If you have it the "wrong" way the timing will be very advanced after you set the static timing visually to TDC.
The main reason you want it the "right" way is the shape of the waveform the system works on . With it the right way you get a sharp trigger pulse as the "finger" on the magnetic wheel makes it's closest approach to the sensor. With the wire set up the "wrong" way the CD is triggered on the shallow upslope of the pulse well before the "finger" reaches the closest approach to the sensor.
-Andy
Old 03-11-2007, 09:30 PM
Early_S_Man's Avatar
Porsche Crest
Green wire SC-ignition question
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 03-11-2007, 10:02 PM
Got it! I thought this is another 'performance gain' trick.
Old 03-11-2007, 11:57 PM
