Running like crap after disuse
I haven't been driving my 911 much lately. I drove it to a show/swap back in October, and before that I hadn't driven it since July or so when I smogged it. As a result, it's all buggered up.
The primary symptom is a heavy miss anywhere past half-throttle. If I try to go WOT, it feels like the rev limiter is kicking in. When accelerating part-throttle, the new rev limiter kicks in around 5000 RPM, although it's not consistent. It's a little rough at idle as well. Any suggestions apart from fresh gas (done) and techron (done)? I'm tempted to just replace the injectors outright, but I wonder if there could be something else funked up that I should look at. Plugs? They're not that old, and I didn't think that storage would foul them. I haven't been to the track in over a year, and I signed up for an event on 4/16 @ Thunderhill. In an attempt to shake out some of the cobwebs, I drove it to work today. That's John Birkett's M491 parked next to me.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
any chance your fuel filter is plugged? I had a similar problem with mine. I had fibers from the inside of the fuel cell plugging my filter (I added a filter prior to the fuel pump).
When it became more acute, my car would die for a few moments following a heavy application of throttle. The pump would have to catch up on the fuel pressure, I believe. My filter is an Earl's. I cleaned the screen on two occassions and the problem went away immediately. Techron would not have solved my problem. Doug
1971 RSR - interpretation |
Thom - I was going to say plugs - but you already did.
I'd first "floor it!" - try some high speed running and see if it clears up - the Italian tune-up is often helpful and usually fun. You can try it cruising right at 5k, then see if you can run it a little higher. If not plugs (or do you have mech. points?), then it is time to think about what could have happened in storage - i.e. animals chewing on electrical wires, debris falling into the wrong hole, etc. I had a similar issue and it was the plugs - they loaded up superfast on my carbed motor - twin-plugging notwithstanding. Good Luck!
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
On the drive home from work yesterday, the car improved significantly, although it's still maybe 75% of 'perfect'
I think I'll go ahead and order up a fuel filter and a set of plugs, just to be on the safe side.
I might check the distributor for moisture, as they set-up condensate may form under cap.
Stranger on the Internet
Moisture is my guess #1. My old farmer's adage of "90% of the time, it's a fuel delivery problem" doesn't apply well to 911's, I have come to find out.
Patrick E. Keefe 78 SC |
I go by the adage that most fuel problems are found in the ignition. After you've been through the ignition twice and ruled that out as a problem, go through it again to figure out what you missed.
That said, I would change the fuel filter.
Chuck Moreland - elephantracing.com - vonnen.com |
chuck +1
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
