Boge and Bilstein Experts -- input pls.
I just received my revalved Bilstein shocks and struts today!
Although I made notes of the parts when disassembly, could you please confirm that:
1. I insert the Bilstein strut into the Boge housing. The collar gets tightened at 140 nM, correct?
2. I protect the strut with the 'green tube cover.' There will NOT be any rubber washers between the strut tower and the 'green tube cover.' Correct?
3. Once I insert the green-tube, there will NOT be any rubber washers between the green-tube cover and the fender/strut-mounting-hole. Correct?
BTW, I used to be able to compress those struts prior to the revalve job. Now, I need to be the Governator to compress them.!!!
Thanks.
Old 03-14-2007, 11:01 PM
