Mike the mechanic
Guest
Posts: n/a
930 intercooler efficiency
Does anyone know the efficiency of a stock 930 intercooler?
Mike
1986 Carrera t
Old 01-03-2001, 07:38 PM
juan ruiz
Guest
Posts: n/a
HEY,HEY,I know were you going....
Regards Juan
Old 01-03-2001, 08:00 PM
Chuck450
Guest
Posts: n/a
Here's a link to some info on different intercoolers. Doesn't give exact efficiency but you can calculate it from these numbers.
http://windward-perf.com/kokeln.html
The stock unit is pretty small and with the bypass valve doesn't help the turbo lag. Although compared to no intercooler it still drops the intake temp a good bit. I have a stock 930 intercooler if any one needs one, I went with the kokeln.
Chuck
83 911 turbo cab
Old 01-03-2001, 08:33 PM
Todd Steele
Guest
Posts: n/a
Mike,
The Kokeln site will give you the surface area, mass, inlet and outlet temp and pres. drop for the stock intercooler as well as some aftermarket. The numbers are for those that fit in the stock location to retain the AC. You can get much better performance if you are willing to give up your AC.
Go to http://www.kokeln.com/INTERCOOLER.HTM
Hope this helps, Todd
Old 01-04-2001, 07:52 PM
Mike the mechanic
Guest
Posts: n/a
Thanks for the help guys!
Mike
1986 Carrera t
Old 01-05-2001, 05:15 PM
