Rick76's Avatar
Send a message via Yahoo to Rick76
Power Window fuse size
Well, trying to sort out a short in my 76, replaced both switches on the driver side, drivers window still only works intermittently, sometimes have to bang on the door, then all 3 switches went out. Did a search ( great wiring diagrams) and made sure all was correct, it was.
Found a frayed wire that may have caused it, checked the fuse and it was blown.
My question is, I pulled a white bullet fuse out of that spot, 16, which I think is only 8 amps and it looks like power windows should be 25 amps according to my book.
Is it possible that white fuse was 25 amps?
I hate electrical problems, makes me crazy.
Rich
76 911S
What ever happened to "If it ain't broke don't fix it"?
"I'm not totally useless, I can be used as a BAD EXAMPLE!"
Old 08-10-2008, 06:00 PM
Danny_Ocean's Avatar
Color Ampere
yellow 5A
white 8A
red 16A
blue 25A
Old 08-10-2008, 06:19 PM
Rick76's Avatar
That's what I figured, just don't understand how the windows worked and the fuse didn't blow with an 8amp when it should have 25
76 911S
Old 08-10-2008, 07:49 PM
If everything is running smoothly, a smaller fuse won't automatically blow. Problems arise in the reverse, when you put a 25a fuse in an 8a circuit and something causes the circuit to malfunction. Poof...melted wires and/or fire.
Old 08-10-2008, 08:37 PM
They most likely used a 25 amp so you could operate both motors at the same time. If you are chasing an intermittent problem look at the ground connections, especially on the drivers side. If you are having problems with blown fuses look for shorted wires were they enter the doors.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 08-11-2008, 07:50 AM
Rick76's Avatar
Ron,
All 3 switches were out, I now have the pass side working from both sides but not the drivers window.
I'm not getting power to the green terminal, I have power to the single top terminal and the 2 below, black and green on mine should be power to the motor correct, getting power to the black
This is frustrating
76 911S
Old 08-11-2008, 10:57 AM
