Czar of C.R.A.P.
dfink's Avatar
useless dl-90 data results
I know they aren't accurate but it does make one smile. Did a 4th gear pull from around 1530 rpm 27 mph to 5900 rpm 98 mph to test hp and torque based on dl-90 datalogger with rpm connection.
Max KW 213.68 hp 285
Max Nm 359.18 ft lb 265
Max torque around 5750
Max HP was still building at 5900
30 to 98 time 18.28 sec
About 2950 lbs with me in it.
Appearantly I didn't get completely stopped to make the 0-60 run but 10-60 5.51
and 10-70 8.01
and 10-90 9.87
all the same run
braking 80 mph to 10 mph 352 feet
I need to get back to the dyno again after my last chip revision. I am guessing I am somewhere in reality around 215 rwhp but I like the numbers one things for sure its no pinto stationwagon.
I understand this is all meaningless but its Sunday morning and have nothing else to do.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 03-18-2007, 11:07 AM
