Throw it on the ground!
Did factory seal inside of evap box?
Anyone know if the factory sealed the inside of the evap box to keep air flow through the coil vs around the sides of the coil? Cleaned my coil this past weekend and there was a uniform layer of an adhesive material around the bottom sides and a little of the same on the sides of the box. If so, should this be replaced to divert air through the coil (there is a good amount of room around the coil for air to bypass)?
The suspect material shown was stuck to the outside of the coil - none in the coil and is the consistency of rubber cement.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I'm curious to hear as well.
Mark- could you use some closed cell foam to perhaps seal around the evaporator? |
Tree-Hugging Member
As I recall, the evaporator core is sealed around the perimeter. I pulled mine about 6 months ago to replace it with a Griffiths serpentine-type core (very nice part, btw) and anything that looked like it used to be foam was quite deteriorated. The Griffiths core had a more substantial piece of rubber around the perimeter and another harder plastic gasket that sat on the shoulder of the evaporator box between the box and the core. Logically, air needs to go through the core, not around it, to be cooled. Any good hvac shop should be able to recommend a sealing material.
"While you're in there" you should probably also check the foam seal between the footwell warm air intake and the smuggler box sheet metal. That was also deteriorated in my car. Also, make sure you don't kink the temperature sensor tube while you're moving that around. The sensor tube fits into a brass receiver tube that goes through the evaporator box cover and into the evaporator core. As I understand it, the receiver tube ideally should contact only the core's fins, not any of the freon tubes. Someone more a/c knowledgeable might have better info on this.
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ Last edited by Jim727; 03-21-2007 at 09:04 AM.. |
Southern Class & Sass
Yes, there is supposed to be a seal between the evap. and the box. You can easily fabricate one using foam strips from your local hardware store.
Dixie Bradenton, FL 2013 Camaro ZL1 |
