LinkBack Thread Tools Rating: Thread Rating: 11 votes, 4.64 average.
911 tweaks's Avatar
what is the name for panel seal gunk?
can anyone help me with what the name is for the roll of gasket material "monkey ****" I call it that goes btwn the front fenders and the body to seal it and help fight off rust and to prevent metal to metal rubbing? This "MS" is Black or a dark color.
Its like a roll of semi cured semi sticky caulking that for those who have replaced window panes in your home, you can get DAP or similar stuff that used to be dark colored and it looked just like monkey ****. Thanks dad for calling it that as thats what sticks in my head and now I CAN'T REMEMBER THE CORRECT NAME!!!!!!!!!!!!!!!!
Thanks guys!
Bob
I live for 911 tweaks...
Old 03-23-2007, 05:03 AM
mattmcginn's Avatar
Dum dum
not you, the product! I use 3M strip caulk, aka dum dum. Maybe terostat tape? Basically a butyl tape-this is flat, the dum dum comes in little strips about 1/4" thick.
Matt McGinn
1984 M491 911 coupe,
69 912 with 901/01 twin plug engine,
57 356 coupe
1972 Alfa Romeo GTV-stock/restored
Old 03-23-2007, 05:54 AM
911 tweaks's Avatar
Thanks Matt. Is this the stuff to use now as porsche or wurth no longer makes this? the 3m stuff better? Is this the studd that you squish btwn the panel and body?
Any tricks on how you have used this, presuming you have?
Thanks!
Bob
Old 03-23-2007, 05:59 AM
911 tweaks's Avatar
stuff not studd...my fat fingers and going eye sight...
Old 03-23-2007, 06:02 AM
mattmcginn's Avatar
I just lay a bead of the dum dum on the mating surfaces-make sure there's not bare metal just for good measure.
Flatten the stuff out a little or it can change the fit of the fenders.
Matt McGinn
57 356 coupe
Old 03-23-2007, 11:31 AM
911 tweaks's Avatar
thanks Matt! Bob
Old 03-23-2007, 01:35 PM
126coupe's Avatar
You can buy Dum-Dum at most Automotive paint stores
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 03-23-2007, 01:39 PM
randywebb's Avatar
Apparently you cannot call it dum-dum in either Orygun or Gnu Mexico -- there is an old thread on it.
There is some wider stuff too that might be better for what you want.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 03-23-2007, 03:38 PM
911 tweaks's Avatar
stop the suspense Randy! You are killing me...What do I call this stuff so I know how to search for it...or better yet, it appears that I am the "dum-dum" so can you please help the challenged and provide the post title??
Thanks, Bob
Old 03-23-2007, 04:53 PM
randywebb's Avatar
I'd call it strip caulk for max. communcations efficiency
if I wanted the ribbon I'd say 'I want that stuff like strip caulk but in a wide ribbon'....
If the guy looks at you blankly - say "you know -- dum-dum"
Report Back. We may be on to some important regional lingusitic divergence or something here...
Old 03-23-2007, 06:04 PM
I think the stuff just holds water. When you pulled the fender what did that area look like? Mine was very rusty, yet no were else was it like that up front.
I think if you ran a bead of the more modern sealers around the mounting holes and between the fender and the body on top where the trunk seal goes, that should keep water from coming up from the wheel well.
IMHO I think it would drain and dry better.
And the trunk seal will hide the bead anyway.
I know it's not for the purist, but I don't want to find what I found the last time.
Silver 1980SC Euro coupe
Old 03-23-2007, 06:19 PM
911 tweaks's Avatar
I think you hit it. I was just talking to a almost retired body guy (early 60's yr old) and he said , "oh that monkey s&^t stuff", I almost fell off of my chair laughing so hard. He said what is so funny? I told him that is what I was told to call it from my dad cus' there is no real good name for it...and...if you break off a piece about about 4" long, you have the proverable Bill Murray thing he found in the golf club pool...LOL LOL
All serious now, Randy, I did see this on Pelican site some time
ago as a porsche item...roll of a caulking stuff to "properly re-fit your body panels to your car like the factory oroginally did" and I cant find it now. It su^&s getting older and forgetting more than one knows ;-)
Bob
Old 03-23-2007, 07:21 PM
haycait911's Avatar
[QUOTE]Originally posted by Ron.G
[B]I think the stuff just holds water. When you pulled the fender what did that area look like? Mine was very rusty, yet no were else was it like that up front.
+1 when I did my bodywork I left out the fender seal gunk AND didn't glue in the trunk gasket in the channel. now I can inspect the seam anytime. so far no issues, it is able to dry out when it does get wet, which IMHO is one of the keys to rust prevention. dry metal does not rust. Don.
Old 03-23-2007, 08:59 PM
randywebb's Avatar
the 3M stuff is in a blue&white cardboard box
IIRC, it (or the bigger version of it) is supposed to keep the fender from rubbing and hitting on the rest of the unit body on bumps, etc.
Old 03-23-2007, 11:47 PM
http://www.automedia.com/Emblem/Installation/res20060101ei/1/
The black gooey sealant that goes into the back of the speed nuts is also known as dum-dum, because it's used for lots of dumb things.
The dum-dum seals things up, which in this case is smart.
marine
http://books.google.com/books?id=qVUD70nM898C&pg=PA166&lpg=PA166&dq=dumdum+auto+body+repair&source=web&ots=yMCh4BU6H5&sig=ruTCFICqGRtrZtj-BqSGNDBkQsw
http://www.rubber-seal.com/prodview.asp?prodID=1467
RS-300
- Dum Dum Strip Caulk
Category: Extruded Sealers
Brand: Rubber-Seal
Size: 2 lb box
MSDS: Not available for this product
TDS: Not available for this product
DUM DUM BLACK 2 LB BOX98 -12 X 3/16 BEADS
http://www.k0bg.com/mounts.html
The best stuff I've seen is made by 3M (Lord, what isn't?). It's called Strip-Caulk, but most folks call it Dum Dum. You can buy it at most auto parts stores. Although it is gooey, it can be removed even years later. What little residue it has is easily removed with denatured alcohol.
http://www.tjmotorsport.btinternet.co.uk/ChevetteMaintenanceSealers.htm
Body interior caulking - applied by caulking gun or stippled with a stiff brush or material supplied in putty form Bostik 1297 or Bostik No.5 Seelastik SR.51 or Seelastrip Butyl Mastic 100 Glasticon gun mastic black or Black dum dum putty 3M Auto jointing seam sealer or 3M Body caulking
http://www.stockcarracing.com/projectbuild/28598_2000_october_imca_stock_car/
We are talking about serious pressure: 12,000 psi. Our purpose was to remove the tar, dum dum, and other body sealers.
http://www.parts123.com/parts123/yb.dll?
parta~dyndetail~Z5Z5Z50000021c~Z5Z5Z589655~P12.95~ ~~~S21T04T63369113122636x~Z5Z5Z5~Z5Z5Z50000021C
Used in places such as the seams in metal, trunk floors, floorboards, the cowl / dash area & on the pillar post. THIS IS THE ORIGINAL DUM-DUM THAT IS USED IN MANY PLACES ON MORE MODERN CARS 3M BRAND 20 YARDS
http://mbca.cartama.net/archive/index.php/t-11908.html
Use 3M body weather strips, more commonly known as dum-dum.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-28-2007, 11:41 PM
911 tweaks's Avatar
thank you everyone for all of your input here!
NOW, the question begs to be asked, what is the factory procedure to attach the front fenders to the tub? i.e. use the dum dum/3m material or not for the front fenders?
Bob
Old 03-29-2007, 04:37 AM
factory used the sealer. It's really up to you if you do it or not.
I won't be driving my car in crappy weather, snow/mud/ big rain storms, so I did not use it. Well I did use it around the fender bolt holes.
If you drive in all sorts of weather I would use it I guess.
I'd rather have it drain and dry then have the water sit there, but thats just me.
Old 03-29-2007, 07:02 AM
randywebb's Avatar
Ron - you forgot to trace the history of it, and critique the history form Marxist, feminist, classical, and pre-post-modern perspectives. Otherwise, great research job!
Old 03-29-2007, 12:32 PM
You might try Butyl tape, the tape is used on RV's, and it is 3/4" X 1/8" and does not retain water
Old 03-29-2007, 07:54 PM
911 tweaks's Avatar
LM3929, a few questions:
1. I have herd of Butyl tape but what is it?
2. Is it a type of caulking in a roll?
3. Is it compressable to get the fender gaps accurate?
4. What is it used for on RV's?
5. by chance have a pic of what it looks like and/or in use?
Thanks! Bob
Old 03-30-2007, 03:29 AM
