RSA door panels
For those that have installed the RSA door panels. How did you install the door pull, i.e. the handle used to pull the door closed. Did you have to drill holes into the door in order to secure it?
- Tyler 1988 911 Carrera Grand Prix White/Black 2015 Cayenne Diesel Black/ Luxor Beige/Black |
I used the inserts provided which do require holes being drilled in the door. They were a bit of a pia but if they get buggered up they have them at the hardware store.
Kevin '79 Coupe |
Yes, you need to drill holes. Not a big deal. Pickup some washers to use as spacers or you won't be able to get the plastic covers on the ends of the handle.
Sean 1982 SC D-Stock #372 NASA GTS2 1971T restoration in progress, read about it here: http://911restorationmadness.blogspot.com/ |
Just make sure that your windows are UP before drilling.
Rob Montgomery '88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running |
Thanks guys, I figured I had to drill and yes I made sure the windows were up. I will say the directions these panels came with were the worst I've ever seen for any product I've ever purchased.
