88 Carrera do I have to remove Intake to Replace Fuel Line?
Hi All,
I have seen some posts on the dreaded fuel leak. But I still haven't seen how to remove the original fuel line from the 2 fuel rails that has a metal T line that goes to the front of the motor and has an L line to the fuel filter. I bought an OEM replacement line and I am hoping that there is a way to do an R&R without having to remove the intake. The front mounting bracket on the line is long and there doesn't seem to be room to slide it under the intake. I removed the air box, blower motor and the air flow meter so the whole intake is exposed and I can reach the front of the motor (towards the front of the car). Please let me know what to do here. Thanks Jack 1988 911 Carrera |
I just removed mine this past week. I read all of the threads posted on this task. After wrestling with the line for a few days trying to get that J shape section out I end up having to reach in and hacksaw it in the back just before the 90 degree turn. Still couldn't get it out so I reached in with side cutters and cut it just past the 90. That took care of everything from the filter to that point. The last 4 to6 inches to the T under the intake has a slight curve to it , so to my surprise it would not exit from under the intake plus the plastic shroud over the fan just would not allow it to come out. So I hacksaw again, oh yeah the blade was in one those single hand frame holder things. Had cut to at an angle but I got it out. What a pia. I took it along with some pictures from some of the earlier threads to a local hose shop. The guy make one for me, 267.00 bucks. I would have preferred the oem I just didn't want to spend the cash on the engine drop and intake removal which from what it seems you have to do to install a oem. Well good luck I plan to post some pictures after I get this replacement line in.
It is very simple to do with the intake off.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
I removed the drivers side intake.
The hard part is cleaning the cylinder head where the intake manifold gasket has cooked on for twenty years way back in there. It might have been easier to drop the engine and not disturb that stuff.
Rick 88 Cab |
You don't have to, but it's a major pain in the butt if you don't. It's probably faster and easier to remove the intake than it is to try to get it off otherwise.
Steve, Can you please give me a small breakdown of how you did it? I don't want to upset the motor by taking off the intake. (I never did a Porsche. Me/Be, Jags, GM, Ford etc-yes) The car I bought new and it only has 14,900 original miles on it. I am sure that it would be easier to remove the intake and replace the line but you know how it is doing something the first time. Thanks Jack |
When I replaced 3.2 fuel lines I went with stainless (there was one very expensive OEM piece that I later replaced as well). Dave White "lowered" the motor by removing the rear motor mounts to allow better access to the motor. Easy to lower down and get in there better.
Regards,
Bernard |
Throw it on the ground!
![]() '87 Fuel Line replacement
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
I think you are underestimating how difficult this is without removing the intake and how easy it is with removal. Removing the intake is relatively easy and affords you the opportunity to replace your oil pressure sender switch, thermostat O-ring, and other preventive maintenance items.
We did this a few years back on an 88 clubsport with no AC and a heater backdate. It was painful even *after* the intake was off. IMHO There is no way to do a clean job on this with the intake installed.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
I am going to try to do it without an intake removal.
All that I have is time................ It is Friday and I can't even get the gaskets till Monday so................................. Was it pulled out and put in from the tranny side or the rear side? Thanks Jack |
I will take Rick's advice and lift the drivers side intake, as I can't do it without opening the hood or going under as Jasper recommended.
Yes, I have a lot of time as there is no work, so I have to save on labor and do this solo. It is time to learn Porsche. Thanks Jack |
Good luck man!
When I was getting ready to do this I PM'd John Walker about how to do it and he wasn't committed to one being easier than the other. Quote:
p.s. From your low post count you must be new on the list but if John Walker had told me the easiest way was to stand the car on end that is the way I would have done it.
Rick 88 Cab Last edited by rick-l; 02-13-2009 at 03:06 PM.. |
engine removal will get you the cleanest and easiest to access job. you don't need to remove the intake that way. i've done it several times without removing the intake with the engine in the car but it's a pain dealing with the bend in the line where it attaches in the center and where it bolts to the left front area. i've straightened the bend somewhat and rebent it after sliding the line into the center area so it can veer left. removing the airfow meter helps. removing the throttle housing helps more. lowering the engine helps even more. never removed the intake though.
I play back harder, I learned that playing hockey. ![]() I took off all of the nuts on the drivers side intake and as I did without lifting it I managed to get the fuel line out from motor front. I managed to get the new line in from motor back (bumper side). I got the bolt on facing me and my light died. I might have to bend the front pipe a bit as it is tight to the filter and i cannot get the hole aligned up. I guess that I can put the intake washers and nuts back on and tighten up without new gaskets. (I did get 12 new gaskets). The new line that goes across the front of the motor is either 1/8 inch too short or i will fight and when I tighten it up it will close. My throttle is like new, remember I only have 14,900 miles on it. Everything is wearing from age not usage. I did manage to pull out the 2 black thin lines and I gather that these are the vacuum lines and each one goes to the top of the controls on the fuel rails that the line that I am replacing is attached to. Thanks for the help. I should have taken pix as I have a lot of parts that I removed to do this. I did notice that on the drivers side, on the middle of the motor there is a 3 plug mount. all 3 on the inside the wire insulation has cracked off. I will have to tape it and rewire it in the future. A Porsche is a strange toy to work on. Not like the rest of my toys. Next I have to do the brakes as they are sticking and from the calipers not returning they are boiling and I lost my pedal. It is all from not using the car. Tomorrow I hope to put the motor back together. When I am done with the lines can I just turn on the key to see if there are any fuel leaks or must the motor be running for that? Thanks Jack 1988 911 Carrera Cabrio 1931 Ford Model A 1953 Jaguar XK120DHC 1963 Jaguar MKII 1967 Jaguar E-Type OTS 1967 Pontiac GTO Convertible 1961 Cadillac Convertible 1975 Cadillac Eldorado Convertible 2006 Dodge Magnum 1997 Jeep Grand Cherokee Last edited by porschzilla; 02-13-2009 at 08:54 PM.. |
