Nose Bearing Dimensions
So since I couldn't stop the leak around my nose bearing/crank spot I decided to split the case. To the naked eye it looks like the bearing is undersized or the hole is oversized. The red o-ring barely makes contact with the case surface.
My measurement show the bearing at 62mm and the opening at 65mm. Anyone know the spec dimension for either? John
1985.5 944 GTS |
I'm guessing someone used the wrong one. I've got two nose bearings here, the 3.6 is 65mm, the 2.7 is 62mm.
BTW, thanks for careful packaging of the roll bar, looks and fits just great ![]() Last edited by 89turbocabmike; 03-26-2007 at 06:17 PM.. |
Thanks. I've got a new one on order and it looks like the 3.0 through 3.6 is the same. Hoping you are right.
John
1985.5 944 GTS |
So...anyone have a bearing laying around they could measure for verification????
1985.5 944 GTS |
Remember
The one I took out of my 3.2 is 65mm.
Gary 1975 911S G50 3.5 Twin Turbo |
Well, the new bearing arrived and fit like a glove. Unbelievable something like that could be done. I guess next time I buy a freshly rebuilt longblock I'll be a little more careful. $200 worth of sealant and gaskets, $100 bearing and about 30 hours to dissassemble. Hopeing she'll be purring like a kitten, or roaring like a lion, by Sunday.
John
1985.5 944 GTS |
John,
The issue you now face is did the 62 mm early #8 main bearing allow adequate supply of oil to the rod bearings for #1,4,2,5 cylinders? I think much passed between the #8 bearing and the case. This may have even lowered the oil to #3 and 6 rods supplied from the #1 main. Doesn’t the oil for the #1-2-3 cams pass through #8 supply? Please look at the big picture. Best, Grady
ANSWER PRICE LIST (as seen in someone's shop) Answers - - - - - - - - - - - - - - - - $0.75 Answers (requiring thought) - - - - $1.25 Answers (correct) - - - - - - - - - - $12.50 |
I agree, but the motor only ran about 10-12 minutes total and the bearings look fine.
1985.5 944 GTS |
John,
Good that no damage was done. I was concerned that the issue hadn’t been brought up and the engine reassembled with potential downstream problems. Good for you. An important feature of any analysis of even a seemingly insignificant issue is to look at every potential effect of every little bit. Nothing should escape consideration. Best, Grady
