a/c question
hi.. i have a question i have a 1979 porsche 911 coupe and im having problems with my a/c blower motor that stop working yesterday. it was smoke comming from the vents but what gets me is i replace the motor last summer and only used it a few times. what do you guys think could be frying it out thanks for the help.
sylvester
Old 03-26-2007, 05:40 PM
Smoke is likely condensation (unless you smell burning- in which case you should get out some marshmallows). Are you sure it's the blower motor and not the compressor? I'd guess your Freon is low which is keeping the compressor from fully engaging. You can recharge but that doesn't fix what caused the Freon from running away in the first place. Unless you are real handy, recommend taking into shop- may places do free A/C system checks in the Spring. Even if you don't have them do the work, at least you've narrowed down the problem
Old 03-26-2007, 05:52 PM
kuehl's Avatar
Re: a/c question
Originally posted by sylvester
hi.. my a/c blower motor stopped working yesterday, smoke comming from the vents, i replaced the motor last summer,
In either event you need to open it back up and see what you have; I've seldom seen a new OE motor fry on its own, many times it is something that stalled the motor such as a fan contacting the case assembly...... open it up and let us know what you find.
Old 03-28-2007, 03:05 AM
Thumbs up
ok.. i will let you know friday afternoon thanks a lot.
sylvester
Old 03-28-2007, 04:16 PM
If you had somebody else replace the blower motor then read this thread before you dive in there
Evap blower and motor removal
Richard Lane
1978 911SC
1973 "Clean" RS clone
Old 03-28-2007, 05:19 PM
