GFCC
Jeff's Avatar
Is there a reason these wouldn't work?
Is there a reason these wouldn't work on an 87 G50 trans mount carrier? I already have these for engine mounts. Once I cut the old ones out these should mount right up, correct?
PEL-PW-CMM1
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 03-28-2007, 11:20 AM
GFCC
Jeff's Avatar
Monday Morning Bump
Jeff
Old 04-02-2007, 07:19 AM
Monkey Wrench
Spede's Avatar
Even if these work... don't do it! They'll rattle your car to pieces on city streets.
But since you already have them you should probably find that out for yourself. I would go with something with a little poly or rubber dampening.
Old 04-02-2007, 07:37 AM
GFCC
Jeff's Avatar
Steve, Thanks for the response. The car is a dedicated track car and is already loud. The only streets it sees is to and from the track.
I just need to know if I will be able to use these as replacements for the old rubber ones without using specialized tools.
Jeff
Old 04-02-2007, 08:05 AM
GFCC
Jeff's Avatar
Yes, No, Maybe so?
Jeff
Old 04-03-2007, 06:58 AM
GFCC
Jeff's Avatar
Bump
Jeff
Old 04-05-2007, 07:09 AM
