GFCC
Is there a reason these wouldn't work?
Is there a reason these wouldn't work on an 87 G50 trans mount carrier? I already have these for engine mounts. Once I cut the old ones out these should mount right up, correct?
![]() PEL-PW-CMM1 Thanks
Jeff 1976 911 Coupe w/ Euro 3.0 - Sold 1987 Carrera Coupe - Sold 1999 Carrera Cabriolet - Current |
GFCC
Monday Morning Bump
Monkey Wrench
Even if these work... don't do it! They'll rattle your car to pieces on city streets.
But since you already have them you should probably find that out for yourself. I would go with something with a little poly or rubber dampening. ![]() |
GFCC
Steve, Thanks for the response. The car is a dedicated track car and is already loud. The only streets it sees is to and from the track.
I just need to know if I will be able to use these as replacements for the old rubber ones without using specialized tools.
GFCC
Yes, No, Maybe so?
GFCC
Bump
Thread Tools | |
Rate This Thread | |
