I'm a loser, baby.
Will a tune up fix this?
If I'm cruising at very minimal throttle and lower speeds, I get a little rough sputter. Kinda like this "brrrrrrrrrrrrrrrrrppppbrrrrrrrrrrrrrrrrrrppppbrrrr rrrrrrrppp". You know?
PO said it has newer injectors, it had been sitting for a while, mechanic said it needs to be ran and to put some fuel system cleaner (I used Techron with Chevron) in it. When I'm on the throttle it does not do it, just when I'm decelerating or just off throttle. Will a tune up fix this you think? I'm not sure of most recent maintanence, maybe I should do a good change of all fluids, tune up and replace the hoses and oil return tubes the mechanic said should be replace at some point soon. Keep in mind I just purchased the car about 2 weeks ago and the PO drove it maybe 500 miles last year. Thanks all.
Which motor do you have? have your frequency valve checked.
Certified Southern Dumbass! 83 911SC with 993 conversion, 98 Ford Expedition 4WD lifted beast, 98 Jeep Grand Cherokee, 01 Ford Taurus, 99 Nitro Bass boat, and a riding lawn mower
I'm a loser, baby.
Sorry, 79 911SC with stock engine. 127xxx miles.
I'm a loser, baby.
Come on ya'll this is an easy one right?
Designer King
I would also check my fuel presures and mixture. It's always hard to diagnose a problem via a written description of a sound. If it is a burble, it usually means a slightly rich mixture. If it breaks up and you can feel the car stumble, it's something else, like above, or maybe a too lean mix.
You may also want to do that tuneup, including new wires and plugs, rotor and cap.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 04-02-2007 at 03:46 PM.. |
Brando
Check gaps, or change plugs and then if not that, then wires I bet. Similat to a bad set of wires I had once except mine was more pronounced.
Turbo powa! 1977 911s. it's cool |
