picture of where flywheel sensors are please?
hi guys can you please post a pic of where the flywheel sensors are please? I have a 89 3.2 carrera which wont fire.... eliminated most things just want to check these but not sure where they are! thanks in advance
Old 04-05-2007, 06:08 AM
Tim L's Avatar
here
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 04-05-2007, 06:23 AM
thnaks for the picture, where would i find this? Sorry im a newbie when it comes to the mechanical stuff, can i get to it from the engine bay or from underneath?
Old 04-05-2007, 07:43 AM
DO YOU SEE THE ALLEN HEAD STUD IN THE FLYWHEEL BEHING THE RELUCTOR RING? IT LOOKS LIKE IT IS IN AT A CANTED ANGLE.
KEITH EPPERLY
87 SLANT NOSE TURBO LOOK CARRERA CABRIOLET
Old 04-05-2007, 07:57 AM
white85carrera's Avatar
you can pull the driver side rear wheel and follow the sensor wires from the engine compartment to the sensor heads. tight fit but all can be done on the garage floor.
Jim
'85 911 Carrera-#008
'23 GMC 2500 AT4
_________________
Old 04-05-2007, 09:52 AM
BTW before you disconnect in the engine compartment tie two different color strings to the connection end of the sensors and tie off inside engine area. Then replace sensors and tie onto string ends to pull back thru into engine compartment and you'll be sure which is which....makes threading back through the opening much easier.
Jim
'23 GMC 2500 AT4
_________________
Old 04-05-2007, 09:56 AM
Originally posted by kepperly
DO YOU SEE THE ALLEN HEAD STUD IN THE FLYWHEEL BEHIND THE RELUCTOR RING? IT LOOKS LIKE IT IS IN AT A CANTED ANGLE.
KEITH EPPERLY
I bet the sensor it hit didn't work very good afterward
Old 04-05-2007, 12:44 PM
Tim L's Avatar
The center of my clutch disk came apart and little bits of metal were flying around and destroyed the allen screw. Replaced the clutch disk and screw everything was fine
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 04-05-2007, 01:20 PM
