FenderGuy's Avatar
Question 2 issues not fixed with newer parts?
Ok what gives I just replaced my fuel sender and head light switch this past weekend with newer used parts that were confirmed to work and still I have the same issues.
My fuel gauge light is going on when the needle is around the 1/4th mark and won't go off. Issue that I had with the old sender and the newer sender didnt fix it.
I have no high beams thinkin it was the head light switch, i replaced it with a newer one, did not fix the issues at all.
any advice?
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 04-08-2007, 08:17 AM
nineoneone's Avatar
High beams are more than likely the turn signal switch. There is a way to repair your old switch. Do a search on here for it. I replaced mine not long ago for the same reason. Not sure about the fuel gauge.
Old 04-08-2007, 08:42 AM
FenderGuy's Avatar
Ok the beams I will do at another time...what about the fuel sender?
Frank
Old 04-09-2007, 10:27 AM
