dweymer's Avatar
915 input shaft seal leak-questions
I rebuilt my trans, and was happy with the improvement, until I found my mystery oil leak was not my flywheel seal, but the input shaft seal(NOT the shift shaft seal). I rotated the shaft and the seal spins with the shaft. I would assume the seal should stay while the shaft turns. I am ordering a new seal, but was wondering what may have caused this so I don't repeat the issue. Also, would it hurt to leave that one in, and put the new one in almost as deep?
Donnie
Currently Porsche-less.....
Old 04-09-2007, 08:50 AM
Tired Member
DaddyGlenn's Avatar
Donnie,
Does this thread help?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 04-09-2007, 09:32 AM
Slumlord
Porsche_monkey's Avatar
That shouldn't happen. How much force did it take to get the seal in during rebuild? Did it go in with finger pressure alone?
Old 04-09-2007, 10:10 AM
dweymer's Avatar
I don't remember, yes Glenn that helped as did a search!
Donnie
Old 04-09-2007, 10:11 AM
Slumlord
The seal should require some force to insert. I would say you need to do some investigation and se if the bore is oversized for the seal.
A sealant MIGHT work, i.e. silicone.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-09-2007, 10:15 AM
dweymer's Avatar
i just pushed the seal into the trans with VERY light pressure. The trans is coming apart tonight.
Donnie
Old 04-09-2007, 10:49 AM
Slumlord
If it is any consolation my Volvo camshaft seal is exactly the same. I pushed it in with finger presure, and now I'm praying it doesn't pop out. Of course it is easier to get at.
In the past I have successfuly installed a 0.005" 'shim' with red loctite in a similar situation, but is very difficult to do.
Options:
1) dis-assamble and have a machine shop bore the OD oversize and change the seal to a bigger size or press in a sleeve
2) using a center punch around the bore to give the seal some grip and then using a sealant
3) sealant only and instal the secondary seal
I would suggest #2.
84 Cab - sold!
Old 04-09-2007, 10:58 AM
dweymer's Avatar
I think I may have excessive end play on the mainshaft....
Donnie
Old 04-09-2007, 11:18 AM
Slumlord
How does that make the seal loose? Did the seal slide forward?
84 Cab - sold!
Old 04-09-2007, 12:17 PM
