-   -   If you're thinking of backdating & you have SSIs... (http://forums.pelicanparts.com/porsche-911-technical-forum/340681-if-youre-thinking-backdating-you-have-ssis.html)
rs6er 04-11-2007 11:49 AM
DO IT!
Just backdated my SC, and heat was pouring in during fast idle warmup on a cold day. Only problem now is the left side of the engine compartment looks empty.
http://forums.pelicanparts.com/uploa...1176317323.jpg
arcsine 04-11-2007 12:05 PM
Agreed. I nearly melted a shoe once when I left my heat on to the footwells unknowingly. My left foot was burning long after I shut off the heat.
81 911 SC 04-11-2007 12:47 PM
now you just need to remove the CAT and install a free flow exhaust, if you have not done so already.
klaucke 04-11-2007 12:52 PM
SSI's have no cat(s) and are quite "free flowing" in comparison to some of the stock exhausts used on G-series 911's (i.e., they are in improvement for a 3.0).
rs6er 04-11-2007 12:57 PM
BTDT
http://forums.pelicanparts.com/uploa...1176321264.jpg
81 911 SC 04-11-2007 01:15 PM
thanks I already knew that
Johnb911 04-11-2007 01:17 PM
If you backdate with Autro heat:
How do you control the heater valves??
rs6er 04-11-2007 01:23 PM
Check this thread:
http://forums.pelicanparts.com/showthread.php?s=&threadid=218738&highlight=backda te+heat+automatic
81 911 SC 04-11-2007 01:27 PM
what do you mean by auto heat? Are you referring to the center dial found on the carerras?
Johnb911 04-11-2007 01:38 PM
Yes.
79 sc ROW
