If you're thinking of backdating & you have SSIs...
DO IT!
Just backdated my SC, and heat was pouring in during fast idle warmup on a cold day. Only problem now is the left side of the engine compartment looks empty.
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. |
Agreed. I nearly melted a shoe once when I left my heat on to the footwells unknowingly. My left foot was burning long after I shut off the heat.
gary |
now you just need to remove the CAT and install a free flow exhaust, if you have not done so already.
- Tyler 1988 911 Carrera Grand Prix White/Black 2015 Cayenne Diesel Black/ Luxor Beige/Black |
thanks I already knew that
If you backdate with Autro heat:
How do you control the heater valves??
JOHN 79 EURO SC "24 Years Later - The Dream Came True" |
Heater backdate and AC on an SC?
John Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance. Last edited by rs6er; 04-11-2007 at 01:26 PM.. |
what do you mean by auto heat? Are you referring to the center dial found on the carerras?
Yes.
79 sc ROW
