Dueller's Avatar
87 CARRERA--Fuel line from filter to rails
After chasing a cabin fuel smell I've found the leak. It is the rubber portion of the line from the filter to the fuel rails.
Part pic...ITEM #9:
If you look at the schematic there is a small leak in the rubber (right under part # 6 above) closest to the fuel filter
Has anybody spliced the rubber line to repair a leak there? How about replacing rubber with braided steel? I realize this line is under pressure, but DAYUM!!!! Nearly $400 to replace the whole part when only failure is the rubber hose nearest the fuel filter?!?!?
Anybody got a cheaper fix?
Old 04-20-2007, 09:27 AM
You could send your hose to get re-done... I'm not sure of your location but there are a couple of threads that mention a place in Orange County CA (LA area)... "La Mesa (something).."
Or BoxterGT from this boards makes them in braided steel for less than OEM prices.
Old 04-20-2007, 09:32 AM
GFCC
Jeff's Avatar
As SoCal said, take it to a hydrolic shop and have them replace the rubber sections. Probably be around $50.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 04-20-2007, 09:40 AM
Dueller's Avatar
Thanks SoCal and L8R....good tips.
SoCal...awesome work on yout project!!!!!L
L8R...how's the track car coming along? Any recent pics of the progress?
Old 04-20-2007, 09:49 AM
Dueller, where are you located?
I had Tom Amon of Mobile Works West do mine, he has some tricks
I recall it being about $50 total.
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 04-20-2007, 10:01 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Pretty common problem which only becomes more common as age takes it's toll. Do a search on here. It's been discussed MANY times.
The lines not only leak at the rubber, but also at the swivel. Porsche stopped making this line with swivel fittings and double crimped them instead. The easy home fix is Oetiker crimp clamps and quality 30R7 fuel rated hose. Some have actually done the hose replacement with the line still in the car.
Also be sure to look at number 19. Number 11 is a bit tougher to replace because the hose is pre-formed. A straight length of new hose will most likely kink and steel braided may not allow a tight enough bend radius for good fitment.
Kevin L
'86 Carrera "Larry"
Old 04-20-2007, 10:45 AM
Just did mine with some AN- line and "blinge hose clamps" that were readily available at the local" house of horsepower". To make sure of no leaks, when I installed the line I coated the ends with real ureathane windsheild sealer. When that stuff sets an act of God is required to separate.
Keith Epperly
87 slant nose turbo look carrera cabriolet
Old 04-20-2007, 11:02 AM
If you are going to have it rebuilt mark the orientation on the rubber hoses with a sharpie before you take it out.
I repalced it with the $350 part couple of years ago. It isn't that easy of a task. I took the intake off, may have been easier to drop the engine.
Old 04-20-2007, 11:03 AM
fancytown
Originally posted by KTL
...Some have actually done the hose replacement with the line still in the car....
But those people have exceptional mechanical abilities unlike any human.
I did the DIY replacement KTL talks about and it's easy. Since your line no longer will swivel, I recommend not crimping one end until it is installed. It's tough to get the fitting oriented correctly, and you don't want to pre-load the hose when you install it.
Just remember to slip the crimp over the hose, and in place loose. You can't get the crimp on when the hose/line is installed.
all cars sold.
Old 04-22-2007, 12:55 PM
plymouthcolt's Avatar
Get thee to a local hydraulics company. A few days later and a few bucks and it will look like this
Been there and done that and it cost me $32.00 and a quarter tank of gas.
If that side is leaking then all the hoses are shot and it is dangerous to keep driving.
I removed the intake, but if I had to do it over, I would drop the engine. DROP THE ENGINE OR YOU WILL GO INSANE AND YOUR BACK BE BE CRIPPLED.
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 04-22-2007, 02:53 PM
