High Idle Solved - Still Won't start/ Hard to Start when Hot
Some of you may have been following my AAR saga. I slowly and somewhat methodically isolated the AAR as the source of my high idle problem. I replaced it with a rebuilt one from Parts Heaven and it idled down to less than 1000 rpm after about 7 minutes. Thank you to everyone who helped.
The second half of my ignition woes is this. Once the car does warm up, if it sits for more than 5 minutes after shutting it down, it won't start again (unless I use starter fluid). My suspicion (from reading other threads) is that the fuel accumulator is not keeping the pressure up. Many people have mentioned I need to check my fuel pressure. (What tool do I use, where do I get it) What are some suggestions for my "Hot Start Problem". Thanks! Hank
Hank 81 911SC |
RETIRED
I would replace the check valve in the head of the fuel pump. Cheap part and usually is the culprit on CIS motors....BTDT.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Thanks Mike! Any other thoughts out there?
Hank 81 911SC |
Is this the part you are referring to?
893-906-093-M5014 Check Valve, (M12 X 1.5 - M12 X 1.5) 911 (1980-83) Brand: Bosch - VAG [Photo] [Photo] [view in parts diagrams] http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M§ion=FULcis&page=3&bookmark=9&part_number=893-906-093-M5014 I didnt realize how expensive an accumulator is.
Hank 81 911SC |
You probably don't have a check valve on your 81, my 80 didn't as it was integrated into the nose of the pump. You need to check your control pressures, specifically the amount of time it takes to reach zero psi after the car has been running.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
RETIRED
Designer King
The fuel accumulator and the fuel pump check valve seem to be the 2 most likely items to check. To check fuel pressures, there is a CIS fuel pressure gauge available from JC Whitney for around $70.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
