Vin-barrett's Avatar
CIS frequency valve question
What is the difference when
O2 sensor wire is grounded
or
O2 sensor is just unplugged
Which runs a higher duty cycle?
Which condition would run richer?
Car in question is a 83' SC
-Vinny
1983 911SC
Old 04-23-2007, 08:24 AM
This is just an armchair analysis--I've never done it--but since the O2 sensor generates a signal, I can't see how it would make any difference. Either way, the system gets no signal and runs open-loop with a fixed duty cycle (right?).
Old 04-23-2007, 09:45 AM
Fixed duty cycle but it's not the same in each situation. I don't have an oscilloscope but there is definitely an audible difference
I read somewhere here it's something like 80% if grounded?
John Walker, Loren or Warren probably know the answer to this
-Vinny
1983 911SC
Old 04-23-2007, 10:18 AM
ttt
-Vinny
1983 911SC
Old 04-23-2007, 03:12 PM
If you want it to run rich, ground the wire going to the temp sensor on the right chain cover. Then, the lambda box will always think the engine is cold and go to a fixed rich setting.
Scott Wilburn
1988 911 Carrera 3.4 L
1998 M3
1984 308 QV
Old 04-23-2007, 05:28 PM
