I will be installing a front cooler on my 69E this year. I am planning on using a set of used 74-89 cooler lines. I have a 3.0 transplanted w/ SSIs. Will I have issues mounting these lines?
joe ------------------ '69 911 E Targa - aka "RoxiE" |
Yes, you will have an issue unless you also change the external oil temp t-stat & oil tank & lines to the '74 up version
