ATP ATP is offline
ATP's Avatar
Bilsteins? need to replace mine
What do I want sport/ orginal? other? I can't afford to swap out the strut but need new shocks. What is my best option? thanks adam
AP
79 Scout II
02 explorer
01 frontier sc
79 sc coupe
Old 05-28-2007, 07:51 PM
ATP ATP is offline
ATP's Avatar
please help, i need to get them ordered to get it out of the shop. currently sitting on stands waiting
AP
79 Scout II
02 explorer
01 frontier sc
79 sc coupe
Old 05-28-2007, 08:15 PM
Buget Suspension
Find the Bilstien site online and get their phone number, call them in the morning. They can rebuild your shocks and upgrade them to heavy duty if you want. But if you upgrade them you have to upgrade your torsion bars as well.
Unless your racing your car you might want to just stick with the stock set up. It will get you back in your car and driving much sooner and less expensively
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 05-28-2007, 08:27 PM
hkiang1's Avatar
I have new Bilstein Sports in my '88. The car rides pretty hard. The shop where I take my car, S Car Go, uses a revalved Bilstein Sport, suggesting that they like a softer rate than the Sport provides but a harder rate than the HD provides. If you don't want to pay for specially valved shocks, but have to choose between the two, bite the bullet and go for the Sports. Leave the "sugarfree" stuff for your other car.
2008 Porsche RS60 Spyder
2005 Jaguar XJR
1994 Porsche 911 Carrera 4
1988 Porsche 911 Carrera (Sold)
Old 05-28-2007, 09:21 PM
did I mix up the two? HD's are stock? My point is and if you read the threads you will see it has nothing to do with sugar free or macho it has to do with the springs and the shocks working together instead of against each other. If you stiffen the shocks and leave everything else stock the springs will not be able to push the shocks back into correct position fast enough. The car will skip more and have less control than the stock set up. Yes, it will feel stiffer. But if you go over a series of speed bumps the shocks will compress more and more until they bottom out and the springs will not be strong enough to compensate.
Skipping can be fun though.
1979 911 SC Targa
Old 05-28-2007, 09:36 PM
Irrationally exuberant
ChrisBennet's Avatar
If you have the (stock) Boge struts on your car you can just get Bilstien inserts.
For a stock car, the HD's are the way to go in the front.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 05-29-2007, 02:58 AM
MOMO3.2's Avatar
FWIW; I have an 87 Carrera Targa that weighs approximately 2,460lbs. The suspension is stock, but it is lowered to just below Euro height. I installed Bilstein Sports and I am completely satisfied with the ride.
I use my car for a short commute to work 2-3 days per week and take it to the twisties most weekends.
Mike
Old 05-29-2007, 07:55 AM
