Throw it on the ground!
Need help with this vaccum line
Anyone recognize the vaccum line in the center of the picture on an 1987? Changed rear shocks recently and must have pulled this loose. Can't find where the end with the golf tee plug goes.
Was at DerkPitt's on Wed doing a little fan recon when we found it. We checked his car ... ...this line, along with the T-fitting on the other end do not exist on his 1998 (correction: 1988). Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 04-30-2007 at 11:17 AM.. |
Toxic
Mark, that's 1988.
The large line is there, but not the T-fitting. And I want my golf tee back. LOL.
Bruce 88 Carrera Coupe, 12 Dodge Ram Hemi, 69 Barracuda Fastback, 68 Barracuda Convertible 5spd The only substitute for cubic inches is cubic dollar$. Last edited by derkpitt; 04-06-2007 at 04:08 PM.. |
I'll just guess based on my '85 that it's connected to the fuel pressure regulator at the front end of that side injector rail.
If so the other end would connect to passenger side regulator or the reverse. I looked at one diagram and the two hoses from the regulators go to a T which perhaps goes to throttle body. Is only a guess. |
Cruise control. The gold colored thing in the above pic by the shock tower.
Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Bump.....I've looked and looked and can't find where this line goes.
Please help. Bruce needs his golf tee back. Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 04-30-2007 at 11:16 AM.. |
Irrationally exuberant
If the cruise control is vacuum powered, two hoses are connected to it:
(1) A skinny one that goes T's into a approximately 1/2" vacuum line (2) A fatter one (~15mm outside diameter) that goes to nowhere - it's a vent. On mine it was shoved into a hole in the body. -Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
My cruise has never worked....maybe this is why. Chris, I enyoyed following you guys cross country...thanks for the posts!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Where is the other end connected? One of the cruise control lines is open to the atmosphere.
Vacuum has one c and two u's. someone told me it's the only only word in eng. lang. that has a double u. |
Problem solved! It was the cruise but my orig picture cropped the location of the top end. Was over at Carnutzzz's (yes, 3 z's)yesterday looking at his 1987 and we found the connection point on the top end hiding directly behind the larger vacuum line at 12:00 o'clock (inside the Carmine Red box).
Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 05-01-2007 at 12:16 PM.. |
Hhhhooooooooooot Pockeeeeeeeeeeeeeeeeeet....
This thread is so pale!
