Follow me
seymore's Avatar
SSI's
I have a 82 SC and I'm wondering if SSI's really do what they claim to do? 10 to 15 more horses, and 30ft lbs more torque? Just Inquiring .Thanks
Old 07-21-2008, 01:41 PM
Peter Zimmermann's Avatar
I don't know what the claims are, and I've never seen dyno numbers, but they are a heckuva improvement. Before your install check your state's smog laws - in CA your car would not pass without the cat & O2 sensor hooked up.
Keep the Shiny Side UP!
Pete Z.
Old 07-21-2008, 01:57 PM
Follow me
seymore's Avatar
I have historic tags so I only had to get it inspected once and thats it for as long as I own it.
Old 07-21-2008, 02:01 PM
You lucky dog!!!
Pete Z.
Old 07-21-2008, 02:08 PM
Trotskyite
I put SSI's and an M&K 2in2out on my '82 and its like a different car for sure.
Grip Fast
Old 07-21-2008, 02:12 PM
AutoBahned
RWebb's Avatar
quite reasonable
they are also works of art - you might want to put one in the living room
Old 07-21-2008, 02:59 PM
all of my customers that have put them on and dyno'd them have shown improvements. hp levels will change with tune etc but it is a big difference in throttle response and heat for sure
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 07-21-2008, 03:59 PM
Senior Member
Superman's Avatar
For sure. They are heads and shoulders above our heavy, non-'tuned' exhaust systems. For heat. And also because the engine simply breathes better through them. As it turns out, the need for backpressure is a wives' tale. What helps is a tuned exhaust where the right cylinders are mated with the right other cylinders, with specific-length initial pipes. This way, the vacuum created when one exhaust valve closes helps to evacuate the cylinder whose exhaust valve is just opening. SSI's do that. Your engine will thank you.
And finally, last but not least, I would say that SOUND is at least half the joy of driving my car. The sound, with SSI's and a proper final exhaust, is intoxicating.
Mocha 1978 911SC. "Coco"
Old 07-21-2008, 04:08 PM
GothingNC's Avatar
They look nice too !!
Check with the members up in the DC area
www.dorkiphus.net
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 07-21-2008, 04:22 PM
AutoBahned
RWebb's Avatar
re tuned - The early cars use a stock 3 into 1 type of exhaust - this gives a bit better torque than a more highly tuned "spaghetti" header.
The SSIs are a copy of the early systems.
What we really need is for someone to make SSIs and mufflers out of titanium. That would save a nice amt. of wt. in the rear, and prevent us from being out-techno'd by 'vette owners...
Old 07-21-2008, 04:27 PM
otto in norway's Avatar
Sorry, but I don't know... But I would also like to know some specifics;
How much do you actally gain?
And what's the story with different engines?
(I have a 3 litre with everything done, except the SSI's... but I guess someone else also needs to know some hard facts... -and NOT subjective)
Anyone?
Old 07-21-2008, 04:35 PM
I belive that HP number gain that is bounceing around was for a 2.7 smog motor that had a very bad exaust.
From one dyno compairsion I saw for a Carrera 3.2 an SSI w sport muffler compaired to stock heater exchangers with a cat bypass and sport muffler the bot make mostly equal HP except at around 3000-3500rpms where the SSI had and advantage of 5-7HP arond the 100hp level. So I would guess about a 5% incress from the SSI's alone right were you will feel it. Add a sport muffer on top of this...
An SC might be different and may even make the CIS work better.
SSI's w a proper muffler sound the best and the bump at around 3k should feel significant.
However, for the $2k (headers, oil lines needed, and sport muffler) I would get a $100 used cat bypass and convert my stock muffler to a sport by adding second exit the the right side and put my dollars into suspention, making the car lite, and track fees.
Just my 2 cents worth.
Old 07-21-2008, 04:45 PM
Bill Verburg's Avatar
every street 911 sold from 1975 to 1994 had a lousey exhaust system from a performance perspective.
SSI's just emulate the earlier design used thru '74 and are sized accordingly, SSI works well through 3.0 but is becoming too small for 3.2 and will totally stranngle a 3.6.
SSI's also work better w/ the lumpier early cams than w/ the later smog cams
Bill Verburg
Old 07-21-2008, 04:51 PM
RETIRED
Joe Bob's Avatar
Just do it.....
2012 ML350 3.0 Turbo Diesel
Old 07-21-2008, 05:27 PM
too bad SSI has nothing in stock for several months due to problems beyond his control on the manufacturing side. i sure hope he stays in business.
206 637 4071
Old 07-21-2008, 05:41 PM
tdatk's Avatar
Pure sex.......Thnx Ben
http://youtube.com/watch?v=grVxwtEgZ80
http://youtube.com/watch?v=DGU2PE2C2JU
Tim
82 SC
90 C2
Yasowatt
Old 07-21-2008, 06:24 PM
fred cook's Avatar
SSI on an SC...........
I put a set of SSI exhausts and a 2 in 1 out muffler on my '80 SC coupe. The biggest difference is felt on the top end. With the original exhaust system, the engine would just quit pulling over about 6200 rpm. With the SSI exhausts I have to be careful to keep the revs under 7 grand in the lower gears. Once the new system was on the car I retuned the engine by cranking in about 2 degrees more advance and richened up the a/f to about 3.5% CO. The end effect was good bottom end and mid range torque with seemingly endless power on the top end. All in all it makes for a very pleasant driving experience. More horsepower? Couldn't say as I have not put it on a dyno. I do tend to "play" the exhaust more than the radio now!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 07-21-2008, 06:52 PM
so if you have an older 911 say a 72 or 73 you won't notice much of an increase in hp right?
Don
_________
72 911T Sepia 2.4
08 Audi A6 quattro 3.2
03 Toyota Tundra
Old 07-21-2008, 07:29 PM
AutoBahned
RWebb's Avatar
none
but they are stainless
Old 07-21-2008, 07:51 PM
Agreed the 75-94 exhausts were all less than optomal.
Again, I believe the 75-77 were the thermal reactor / log style and Porsches first attempt at a smog exhaust and thus the worst of the bad.
I trully think the big 10-15HP increase quoted and bouncing around for the SSI's was for the 75-76 2.7.
A 3.2 might be different but SSI's do not add any peak HP over a cat delete from the dyno numbers I have seen except for about 7hp near 3500rpms.
Go to an overlap cam and the scavenging available from a well tuned equal length long tube header should have a significant effect.
Now a 3.0 with S cams and SSI's, that would be fun.
Old 07-23-2008, 06:39 PM
