What?
Eric Hahl's Avatar
What type of grease on rubber sway bar bushings?
I'm in the process of install the suspension components an am wondering what type of lubricant to use on the sway bar bushings. Just standard grease or?
I am using the stock rubber bushings and they have a grease groove on the inside surface.
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 06-29-2013, 09:07 AM
ninelevenick's Avatar
I believe in the 101 Projects book Wayne suggests white lithium grease. That is what I used.
Old 06-29-2013, 09:22 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Petroleum grease will make it stick, just like if it was dry/no grease.
Chuck Moreland says no grease. He's the Elephant suspension guru, so i'd give the nod to his recommendation
Should front Sway Bar Bushings be Greased?
Kevin L
'86 Carrera "Larry"
Old 06-29-2013, 09:24 AM
Functionista
manbridge 74's Avatar
I believe the factory spec was glycerin but likely for ease of install and maybe some preservative effect. Dry is fine as 'lubes' will not last very long.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 06-29-2013, 09:40 AM
Cajundaddy's Avatar
Petroleum grease will attack the rubber and age them quickly. You can use lithium, silicone or run em dry. I prefer a dab of silicone grease.
2009 Cayman PDK With a few tweaks
2021 Cayman GTS 4.0L
2021 Macan (dog hauler)
Old 06-29-2013, 10:30 AM
