3.2 DME Wiring questions
I installing a Euro 3.2 and I am trying to figure out the wiring that goes to the front fuse panel. Below are the wires I have. Any help would be greatly appreciated and I cannot seem to find the correct diagram.
Thanks in advance,
Wires I have:
1 Large Red Wire
1 Large Black Wire
1 Yellow Wire
1 Green and Yellow (stripe) Wire
1 Large Red and Green (stripe) Wire
2 Small Black Wires
1 Small Black and Violet (stripe) Wire
Old 05-04-2007, 12:21 PM
Check this thread, there is some DME wiring info:
1985 DME/14 pin wiring to fusebox
Old 05-04-2007, 01:23 PM
Hey thanks I have checked that out but I still have a couple wires that I cannot figure out where they go. I am still at it though....
Old 05-04-2007, 01:28 PM
Kelly,
I chased my tail for a while looking for 3 of the DME wires only to find out they were connected by the pedal cluster, so depending on your setup, some of the DME wires do not extend to the fuse box. From memory, the thick red one is connected to the battery +, the red/green is what feeds power to the fuel pump, the black/purple goes to the tach, the small black connectes to fuse 8 (backup lights). Let me know if there are other connections you're missing and I'll check my car tonight.
Old 05-04-2007, 01:32 PM
Hey thanks I am going to try and finish it up today and I will post progress.
Thanks!@
Old 05-05-2007, 09:56 AM
Hey SoCal I sent you a PM
Old 05-08-2007, 04:46 PM
