-   -   Butt welding flares vs. lap welding (http://forums.pelicanparts.com/porsche-911-technical-forum/345010-butt-welding-flares-vs-lap-welding.html)
berettafan 05-05-2007 01:46 PM
As i am learning to weld i am curious how exactly flares can be butt welded. It seems it would be impossible to perfectly match the cuts on the chassis and flare. What am i missing?
Also curious to know whether those of you who do a lot of 911 metal work prefer Mig or Tig.
Thanks for the input-
Erik
rfuerst911sc 05-05-2007 02:45 PM
I am in the process of butt welding GT flares on my 914 but it's the same for a 911. I have never done this before but I did a lot of research on the web and then decided to do it. What I am doing is I get the flare clamped in place and take all the vital measurements to determine it is in the right location. Once I know it's good I put 4-5 self-tapping sheet metal screws thru the flare and into the existing body. I then use a jig saw with metal cutting blade and cut thru the edge of the flare and the fender, this leaves a exact seam does that make sense? I'll cut about 10-12 inches and stop. I'll peel away the existing fender and install welding butt clamps to hold the seam tight and do a couple of tack welds. I continue this process until the flare it tacked all the way around. So far I have done the rear flares on both sides and this has worked great. I am doing this with a Hobart 140 mig welder with .025 wire and 75/25 shielding gas. Hope this helps.
afterburn 549 05-05-2007 02:59 PM
I could say do a search.....but after you do butt weld is the ans. Just remember to give it all a good hammering after the job to relax it all
kycarguy 935 05-05-2007 03:17 PM
Here is a thread that is incomplete now. It may help some.
http://forums.pelicanparts.com/showthread.php?s=&threadid=165052&highlight=slant+ nose+turbo+look
Zeke 05-05-2007 03:58 PM
Re: Butt welding flares vs. lap welding
Erik
Whatever you have will work. The trick is to use as little heat as possible to do the work. Only weld a small amount at a time. People always say this, but they don't know how much heat it takes to start a weld. With MIG, the weld is started almost instantly, but MIG welds are hard; not very malleable. TIG works nicely, but not everyone has one or knows how to properly use it. It takes a couple of second to start a bead. This is unwanted heat.
Oxy/gas might be the preferred method of the accomplished welder, but a lot of heat can be introduced if not really good at it. The trick here is to use a real, real small tip and MIG wire as the filler because welding rod smaller than 1/16th is hard to find. And, get some Cool Blue welding heat sink paste.
If a team were to do the welding, that would be ideal. One to weld, the other to hammer and cool. One just doesn't have enough hands to handle the torch, the welding lens over your eyes, find the hammer and dolly, then hit the weld with air or a wet rag. It's like juggling. 3 balls, 2 hands
Lukesportsman 05-05-2007 05:29 PM
As an amateur (installing my 5th set of quarters, at this moment on a Buick GS), Milt's thoughts are so accurate. Good luck getting the helmet up, tip down and hammer and dolly ready before the MIG weld cools.
I don't think any amateur should try Oxy/gas on cosmetic thin metal welds.
Use thin wire in your MIG (.25), this is handy.
Take your time, check twice before stitch welding after the tacks. I prefer Clecos to attach panels. You'll likely be proud of your task afterwords.
Grinder: take smooth long passes and don't try to grind down small sections. It may seem to take longer but less likely to form gouges.
BertBeagle 05-05-2007 06:10 PM
Re: Re: Butt welding flares vs. lap welding
If you like to gas weld you would really like one of these. I have had the weldit mdl 101 for years - it is a great tool.
http://www.victortorch.com/weldit%20gasaver.htm
Victor, for one, makes the small tips good for this kind of work.
kycarguy 935 05-05-2007 06:17 PM
Lukesportsman, I have a 69 Buick GS that I'm restoring also.
berettafan 05-06-2007 03:44 AM
what is the purpose of hammering after the weld?
jhelgesen 05-06-2007 04:55 AM
I had all the same questions.....
http://forums.pelicanparts.com/showthread.php?s=&threadid=213651&perpage=20&highl ight=flare&pagenumber=2
http://forums.pelicanparts.com/porsche-911-technical-forum/216930-912-6-now-flared.html?highlight=9126
berettafan 05-06-2007 09:18 AM
thanks for the links john. that pretty much explains it.
i am not going to be doing flares myself, just have some pan area work to do and a small floor pan hole to patch. i just wanted to understand the process a bit more.
rennch 05-21-2007 08:27 PM
What measurements did you take? I would like to get my flares perfectly aligned...I'm ready to weld now. I think that method you described is a great one though...it's gotta be the right way to do it. How much of the new flare did you cut off?
Any pics to share?
rfuerst911sc 05-22-2007 01:36 AM
Any pics to share?
The measurements I took are available on the net for the 914 GT flare install but I'm sure there must be measurements available for the 911? I always have trouble adding pics but if this works here is a pic of one of my flares.http://forums.pelicanparts.com/uploa...1179826584.jpg
jhelgesen 05-22-2007 04:00 AM
I lined up using the torsion bar hole, then rear flange on the back. Put a couple of sheet metal screws to hold in place.
rw7810 05-22-2007 09:51 AM
They now have this new MIG wire from Harris called "20 guage" that is powder filled, designed for light sheet metal work.
rennch 05-22-2007 09:54 AM
Does the wire make a big difference bob? I need to see what I have in my MIG before I start this, I think.
rw7810 05-22-2007 10:18 AM
I haven't used it, but have been reading about it on various hotrod, welding sites.
Some links:
http://www.millerwelds.com/education/projects/mboard/showthread.php?t=532
http://www.harrisproductsgroup.com/consumables/alloys.asp?id=11
Some links:
http://www.harrisproductsgroup.com/consumables/alloys.asp?id=12
mattmcginn 05-22-2007 01:31 PM
Heres how I do it:
I'll weigh in here as I just did this exact project on a 911 and have done many similar things on other cars...
Background: car is a 79 SC that we're building as an IROC inspired hotrod.
To answer a question in the thread, it is difficult to get the flare to butt nicely-but not impossible. Using the following I can usually get everything nice nice with about a 1/32" max gap. Using the following method you can do door bottoms, etc-any butt welded repair/modification.
Start by using some good measurements-i.e. torsion bar holes, rear lip above the valence, etc. to position the thing roughly.
Line it up, then make a line on the body where the new/repair panel overlaps-then take the flare off and grind off the paint about an inch or so from each side of the line.
ALSO grind off the undercoat on the bottom about the same amount. Take it down to bare, shiny metal. Use one of those resin discs like a Norton Beast-they do not thin the metal like grinding it. You DONT want to thin the metal, its thin enough already...and you'll burn through enough as is...
Anyway, that was your rough line just to get a ballpark idea of where the part will go. NOw you have bare metal to scribe your actual cut line on-its much easier to see and make an accurate cut on bare metal than on painted metal.
Now, working with the flare, trim the edge so the edges are not wandering (from the stamping process) so they form a nice symetrical arch. Wandering lines are tough to weld accurately. Sometimes I do this by stretching a piece of tape along the edge and then tracing the tape edge...trim to the tape edge or the line you made, now you have a nice even edge...
http://s94994139.onlinehome.us/album...8/P1010057.jpg
Line it up as above but more accurately if you did the above just roughly, use some sheet metal screws/cleco's/rivets to hold it nicely tightly.
Scribe the quarter panel on the car thusly:
http://s94994139.onlinehome.us/album...8/P1010077.jpg
I use a super sharp scriber to get teh tip right down at the edge of the flare. Its also a good idea to make some hash marks that will allow you to index the flare once everything has been removed because you will then have no reference point.
Now remove the flare, use a 1/16" or thinner cut off wheel to make the slice on the OUTSIDE of the line you just scribed. If the line has a great curve, you'll want to use a smaller wheel as it will be easier to make follow the curve without making the cut choppy and innacurate-either that or just dont bury the wheel when you're cutting:
http://s94994139.onlinehome.us/album...8/P1010072.jpg
Now your flare is off-and holding it in place will be really tough as you cant clamp it too effectively, so its best to use your index marks and have an assistant who has not been drinking hold it in place while you tack weld it in a few areas.
http://s94994139.onlinehome.us/album...8/P1010082.jpg
Like has been said, you need to work slowly. Each tack weld, until you get them spaced about a half inch apart will need to be hand dollied to make sure the two adjoining panels have no offset between them.
http://s94994139.onlinehome.us/album...8/P1010085.jpg
http://s94994139.onlinehome.us/album...8/P1010001.jpg
Note the use of a small chunk of angle iron to make sure there is no offset between the panels-you could also use padded vise grips to accomplish the same thing.
Keep a clean small wire brush (toothbrush size) handy to clean your welds after you do them to make adjacent welds nice and clean.
http://s94994139.onlinehome.us/album...010014_003.jpg
(note-wheels are "Rollers" that are too narrow and I think we were taking the rear valence off because its hanging a bit low...)
Once you have 100 percent welded the flare, its time for grinding the welds. This is AT LEAST as important as your welding for determining how the end result is.
I grind welds thusly: I use the same cut off tool that I run an .045 cutoff wheel in, but I use an 1/8" so called cutoff wheel. This way you can grind JUST the weld and not the surrounding metal-its very controllable. I dont have a pic of this but its something that does not carry over well in a pic anyway. I hold the tool at a variety of angles to achieve the nice result I want-you just have to learn what works for you.
One thing I do is mark areas where the welds may not have penetrated well enough or where there were spots I missed. I then reweld these areas afterward and grind, etc.
ONce its all ground, you can hit it with a DA with some 80 grit to make it really pretty like this:
http://s94994139.onlinehome.us/album...8/P1010023.jpg
Sit back and marvel at the work you've done!
rennch 05-22-2007 01:38 PM
Thanks Matt...great post. I assume that you go back and stitch weld between the tack welds before you grind it. What do you think about the technique of attaching the panels and cutting them both at the same time with the body saw? Then tacking 10" or so at a time?
Kemo 05-22-2007 02:15 PM
mattmcginn,
EXCELLENT WORK! Thank you so much for posting your technique. I do have a question. When you start tacking in the flare, do you position the flare flush with the body with no gap at all? after reviewing the "cut a little and weld" technique, it seems there would be a gap from the cutting blade. Your technique seems to offer up a flush welding surface thereby minimizing the "blow thru" problem that newbie welders like me have.
thanks again for posting.
rennch 05-22-2007 02:22 PM
Kemo, I was thinking the same thing. That said, if you used a body saw, the gap would be very minimal. Just enough for a sheet metal clamp to fit in perhaps.
Kemo 05-22-2007 02:33 PM
emptyo,
I read somewhere that the metal shrinks at the weld. with the metal flush you would think it would shrink and pull the flare either up or down depending on which side of the weld cooled faster. so is that the reason for a hammer and dolly? to get the flare back flush with the body metal?
rennch 05-22-2007 09:14 PM
Yes, if I understand it correctly, the hammer and dolly takes the tension off the weld. I guess ideally you have someone there with a hammer and dolly ready to rock between spot welds so it stays consistent.
rw7810 05-23-2007 05:56 AM
I think when you butt weld you should have a small gap. These ltittle tools help.
http://forums.pelicanparts.com/uploa...1179928569.jpg
Matt - thanks for your great contribution!
mattmcginn 05-23-2007 06:49 AM
Bob
I've seen those tools you posted but have not used them myself. One of the guys who works for me likes them and gets good results with them so its a lot a matter of preference. I learned the trade doing tons of 365 work at Karosserie Kolbe doing all straight butted welds (there are tons of butted joints on the outer skins of the 356)
I wrote up a big reply at home last nite and never posted it-maybe it will still be there when I get back but I am at my shop now...if its there I will post tonite.
Basically my millermatic 185 set on to run 30 percent of max voltage and 50 percent of max wire speed has no problem with full penetration and working slowly, has no warpage problems that are out of whack from any other welding on sheet metal. In fact, I usually have to dress the hangers on the back side of the weld prior to doing and final hammer/dolly work.
Welder settings are hugely a matter of taste and style. Ditto for basic welding practice. I say if it works for you, do it and have fun!!
rw7810 05-23-2007 07:00 AM
I have the same Miller, but still a rookie with it. Thanks for the set-up tip. i'll try that next time.
rennch 05-23-2007 07:15 AM
They actually have those sheet metal clamps (the illustration above) at Harbor Freight for just a couple bucks. We're lucky enough to have a local retail store right around here.
mattmcginn 05-23-2007 07:42 AM
Its a great welder. I have had mine for 7 years and have had no problems. I have welded 3/8 plate/tubing for my english wheel all the way down to thin body metal.
Getting a welder dialed in to your preferences can be a bear. One of the things you may have to do is to push the wire just as you strike the arc to artificially increase the wire speed in certain areas where you may need to fill a gap.
rick-l 05-23-2007 07:44 AM
They are only available in the stores, not in the on line catalog. I did a search for the part number on their website and came up empty.
rfuerst911sc 05-23-2007 01:01 PM
Those are the clamps that I use, I purchased them from Harbor Freight.
rennch 05-23-2007 01:23 PM
Wow, deja vu! :)
squidmarks 05-23-2007 03:48 PM
I'm glad to see this discussion as I plan to add turbo flares to my SC. I just finished rebuilding the engine and will now start stripping the body.
Where's the best place to buy steel flares? How much can I expect to pay?
Thanks.
Geoff
rennch 05-23-2007 10:11 PM
A lot of folks get them from Restoration Design, if Bill is actually there to answer the phone. I think you can expect to pay $200-$250/corner, generally, unless you can find a Pelicanite that's got a couple lying around. :)
village idiot 05-23-2007 11:41 PM
like me:D
http://forums.pelicanparts.com/uploa...1179992421.jpg
http://forums.pelicanparts.com/uploa...1179992438.jpg http://forums.pelicanparts.com/uploa...1179992454.jpg
http://forums.pelicanparts.com/uploa...1179992471.jpg
http://forums.pelicanparts.com/uploa...1179992487.jpg
rennch 05-23-2007 11:47 PM
Hey Village...I'm in the market for front flares. What do you want for 'em?
village idiot 05-24-2007 12:27 AM
I just picked these up, and I'm debating to use them right now. If I decide to get rid of them I'll let you know.
I just figured the chances of anyone having a complete set in Hawaii was so remote that I'd better buy them before someone else did...just in case :D
rennch 05-24-2007 07:29 AM
Fair enough...keep us posted!
Gillies 10-17-2010 05:21 PM
Subscribing... Great thread !!
T77911S 10-18-2010 05:30 AM
i did not read any replies.
when i did some, i screwed the new flare on as the one picture shows the guy scribing it, except i left it on, cut about 12 inches or so of the old flare, spot welded the new one, cut, spot welded and so one until the old one was cut all the way off. then remove the screws and the old one will fall off.
